OSB Sheathing As Siding? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 10:57 AM   #1
Rewards Points: 150
OSB sheathing as siding?
I built my shed 7 years ago and when I built I use OSB as siding and painted it. Now the bottom part is rotten I am planning on cutting the rotten part off and replacing it with treated 1x6 boards. And repaint the shed? I am wondering is it a good idea or I need to put up lap siding over the OSB. The top of the OSB is not rottening.
CJIII is offline   Reply With Quote
Old 12-24-2011, 02:03 PM   #2
Tizzer's Avatar
Rewards Points: 452
The bottom probably rotted cause the osb wicked water through the edges, that and/or rain splash. If the shed is small, why not just put some vinyl siding over it and be done.
Shouldn't cost that much.
Tizzer is offline   Reply With Quote
Old 12-24-2011, 02:16 PM   #3
I agree...water wicked up and rotted the OSB. OSB shouldn't be used as the exterior siding.
pkrapp74 is offline   Reply With Quote
Old 12-24-2011, 03:36 PM   #4
Registered User
Rewards Points: 5,212
OSB can be used for structural sheathing (rated as such), not exterior siding (they do make a structural siding panel).
If the shed is large and the panels are for shear transfer, solid wood block the bottom after removing the rot to gain shear value lost from cutting. It is used for sheathing, cover it with a water resistive barrier (as per code) and siding of your choice.
Gary
Old 12-24-2011, 04:06 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
gary is right,
id cut out the bad sections and replace. from there put house wrap on and vinyl siding for a quick cheap fix
woodworkbykirk is offline   Reply With Quote
Old 12-24-2011, 05:49 PM   #6
Rewards Points: 150
I been thinking about using tounge and groove pine siding since it comes in bundles. I know how much it cost compare to vinyl siding. I need to jack up the shed to put on put blocks and replace rotten sill plates. Then proceed to fixing the roof.
Old 12-24-2011, 06:20 PM   #7
DIY staff
Rewards Points: 7,174
CJ--Pine for siding can be a maintainence issue--It doesn't hold paint well outside--Just a thought--
Old 12-24-2011, 06:25 PM   #8
Rewards Points: 150
What about LP smartside lap siding?
Old 12-24-2011, 06:34 PM   #9
DIY staff
I'm an inside guy--so we'll have to wait for someone with some experience there to chime in---
Old 12-24-2011, 06:47 PM   #10
Rewards Points: 150
Ok! Its like $4.89 for 12 ft lenght at HD!
Old 12-25-2011, 10:53 AM   #11
Facilities Maintenance
Gary
On some houses I've done work on, some wise guy when building them used OSB for siding. On several older homes I've found myself helping the owners in replacing to LP siding.
That said, would you normally use LP siding? It's the most common I come across. (aside from the wood shingles that rot after 4 or 5 years down to the houses plywood) Not sure if the cost would be worth it for a shed or not.
BigGuy01 is offline   Reply With Quote
Old 12-25-2011, 11:01 AM   #12
This one
http://www.homedepot.com/Building-Ma...atalogId=10053
This one
and this one
and this one
Are the four I've used. They each meet building code, and they last for decades.
But they aren't cheep. TBH, I'd take off the siding for each side of the shed, and simply redo it with appropriate siding. Use the plywood and tyvek as GBR stated, but then try one of these ^^^
Old 12-25-2011, 11:18 AM   #13
kwikfishron's Avatar
Rewards Points: 176
I'd use LP on a shed, that's about it though. Just make sure to keep it well painted.
I'm not sure what type of wood shingles your referring too but Red Cedar Shingles are good for 30-50 years (untreated) depending on the exposure to the elements.
kwikfishron is offline   Reply With Quote
Old 12-25-2011, 11:30 AM   #14
THe shingles I've had to replace, were only on the house for 5 years. And they broke apart in my hand. Don't know if they were cedar, just know that they were wooden shingles for siding.
Old 12-25-2011, 03:26 PM   #15
Rewards Points: 150
The LP Smartside looks like a good choice. What about T1-11 on top of the OSB?
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 07:56 AM
Sheathing with foamboard under siding billybarty Building & Construction 6 04-18-2008 01:46 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
