OSB Expansion - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-25-2009, 03:04 PM   #1
Red face
OSB expansion
I recently lined the inside of my work shop with 7/16 osb, walls and ceiling.
Being quite anal I made sure every joint was tight as well as were the walls met the ceiling. My question now is , now that I'm done, how much will osb expand and contract?
Barry2080 is offline   Reply With Quote
Old 11-25-2009, 03:21 PM   #2
Civil Engineer
Rewards Points: 4,572
There are different grades of osb. I believe most of it is rated esposure grade 1, meaning it is suitable for use in damp environments, but not designed for immersion in water. OSB for sheathing is typically installed with 1/8 inch gaps between boards, presumably on the theory that the boards might get wet.
As for long term expansion contraction, OSB is an engineered wood product, so the individual fibers would typically expand and contract between 1 and 2 percent as they cycle between minimum and maximum moisture content. If your basement remains at roughly the same humidity level all year, you will not experience any movement. If the humidity level changes over the course of a year, the movement would likely be less than the 1 to 2 percent typical of wood, since there is so much glue in osb.
Daniel Holzman is online now   Reply With Quote
Old 11-25-2009, 03:59 PM   #3
Registered User
Rewards Points: 5,236
"I recently lined the inside of my work shop with 7/16 osb, walls and ceiling." ------- If outside where it rains a lot and there is no heat, I would be concerned. The rating, as Daniel said: http://osbguide.tecotested.com/pdfs/en/el812.pdf
Compared to plywood: http://www.gp.com/build/PageViewer.a...elementid=6132
Be safe, Gary
Old 11-26-2009, 11:04 PM   #4
osb blues
that's a good question. maybe for good measure, use a penny as a spacer next time, but by all means keep it off the floor at least a 1/4 inch. osb does not like moisture as it's thickness expands. iv'e never seen it buckle though, it just puffs up when it gets wet. wood cells are elongated, like rice. when wood gets wet it gets fatter but it never gets longer. maybe wood is like people, when we over eat we get fatter but we never get taller from it. maybe that's why osb doesn't seem to change much in height or width, just in it's thickness as the strands are placed every which way and when they do expand, it's just gets fatter. mdf (medium density fiberboard) is something to avoid in high humidity areas. if you wanna have a good laugh, or cry, use mdf in a basement. been there, done that. good question though.
dale's nails is offline   Reply With Quote
Old 12-16-2009, 02:14 AM   #5
Phil
OSB expands at different rates across the panel as it is a hodge podge of wood and glue. With plywood any swelling from moisture is uniform which is why it is preferred for subflooring. For an interior application OSB should be fine as it is not likely to absorb much ambient moisture and I expect you plan to paint it. Sheetrock is commonly used and in high humidity situations it is going to cause a lot more problems with absorption than any wood product.
Phillysun is offline   Reply With Quote
Tags
expandtion , osb
Expansion tank location?? rcassidy HVAC 4 10-06-2009 10:01 AM
Laminate Expansion Gap & Room Size BataviaJim Flooring 7 03-25-2009 07:50 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 06:44 AM
expansion joint farrington135 Building & Construction 1 01-27-2006 11:02 PM
