Ordinarily While Jacking Floor Joists... - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 07:55 AM   #1
I ask the impossible!
Rewards Points: 712
Ordinarily while jacking floor joists...
So from what I understand, ordinarily when you're jacking up floor joists you go 1/4" at a time and you expect to hear creaking and groaning.
I've had to jack up floor joists more than that, even 1" at a time, just to get them off the "supports" I'm removing to put in my temporary support beams. Not a sound. Am I deaf? Is my house built from wet noodles?
On one hand I'm wondering if something ain't quite right. On the other, I'm wondering if this means I might have enough flexibility in my structure that I have a good chance of being able to straighten it out before I start sistering and getting the structure into a better state. I.E. the old structure will conform well to the newer more rigid structure.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 08-23-2011, 08:43 AM   #2
Rewards Points: 5,336
If you hear nothing and see nothing, I wouldn't worry about it. As long as you adjust the temporary supports as you go, the load will be supported properly.
Ron
B. Franklin 1759
JAcking up floor to replace bottom wall plate. tpicklesimer Flooring 0 05-24-2011 07:08 AM
Proper jacking method? revrsemigration Building & Construction 4 10-31-2010 03:53 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
what size beam for jacking up floor joists ponch37300 Building & Construction 19 02-07-2010 09:13 AM
Jacking main beam/floor joists gshock Building & Construction 1 05-30-2007 08:17 AM
