Options For Cased Openings - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 12:55 PM   #1
Rewards Points: 121
Options for cased openings
I've been reading all the Q & A's under "cased openings", and would appreciate any ideas for my situation.
Remodeling an older (1965) home that has had some updates where several doorways have been left with finished sheetrock that is not standing up well.
I would like to finish them with jamb and casing, but without pulling off the sheetrock. However, I hesitate to give up and inch or more of the opening size. (Also,the jamb widths of the different openings vary from 5 1/2" to over 7", so I will need to customize them anyway.)
I'm wondering if there is some type of thinner wood (1/4") I could use on the jamb, where I could route the edge to still get a nice reveal with the casing.
Then I was thinking of using both adhesive and finish nails to attach it and prevent any warping.
Thanks for any advice.
JamesRW is offline   Reply With Quote
Old 02-10-2013, 01:18 PM   #2
Rewards Points: 13,750
That would look like poop.
Why would you not want to remove the sheetrock?
You could go with back band moulding to give you a cased look.
http://www.appalachianlumber.net/M1.htm
The Following 2 Users Say Thank You to joecaption For This Useful Post:
mae-ling (02-10-2013), woodworkbykirk (02-10-2013)
Old 02-10-2013, 01:22 PM   #3
MarginallyQualified
Rewards Points: 2,464
Single door width openings? eg: less than 36"
If so, then damage from passing through is understandable.
I would like to finish them with jamb and casing...
I'm wondering if there is some type of thinner wood...
Cutting to the chase:
Your choices are enduring the occasional spackle & paint repair job;
or losing 1.5" of clearance to 3/4" stock on each side;
or removing the GWB and attaching that 3/4" stock onto the framing.
Old 02-10-2013, 03:05 PM   #4
Rewards Points: 121
To further clarify, I will be using casing on all the doorway sides and tops - just wondering if a "facing" rather than a 3/4" thick jamb could work.
The corners all seem to have good structural integrity, except for chipped paint, etc.
Old 02-10-2013, 03:18 PM   #5
Those corner will have steel outside corners so there no way to nail the casing that close to the outside edge. 1/4 will leave you nothing to attach the casing to and will leave an exposed rough surface.
Over all it's just a very bad idea.
Old 02-10-2013, 09:06 PM   #6
Rewards Points: 2,212
yep . carefully rip out the drywall and install 3/4" (or 5/8") jambs and casing. the jamb/casing will cover any ugliness left by a careful removal of the metal corner trim on the drywall.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
JamesRW (02-11-2013)
Old 02-11-2013, 08:40 AM   #7
I just use a hammer and tap it along the outside edges and the joint compound just pops right off so you can find the nails or screws.
In less then 1/2 hour you can have it all off and ready for the new jambs.
Any box store will stock premade wooden jambs already cut to width with nice rounded edges.
Old 02-11-2013, 09:44 PM   #8
Rewards Points: 960
You could use 1/2" solid wood jambs if you want, and still get a 1/4" reveal.
I used to use 7/8" jamb material and have a 7/16" or so reveal. It looked real rich. Then I started using 3/4" oak plywood, so you can't have any reveal.
cleveman is offline   Reply With Quote
Tags
cased opening , custom jambs , millwork
Inexpensive Siding options that that aren't Vinyl or Metal GumbyMan Building & Construction 15 01-06-2013 11:01 AM
Recommendations for heating and cooling options for my home? daluu HVAC 2 12-23-2012 01:31 PM
Maytag dishwasher has 5 cycles and three options. only one cycle works and no options wwejj0926 Electrical 1 04-22-2012 05:54 PM
Large metal "tabs" in openings cut in bi-level rim joist... What are they? Insulate? nutlog Building & Construction 9 11-09-2009 03:19 PM
Filling in large openings in concrete foundation shtoink Building & Construction 10 12-04-2008 04:03 PM
