Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-11-2012, 12:33 PM   #1
Question
Opinion on closet door trim
Greetings all,
I'm new here (first post) but from what I've read in looking for my solution I think this is a great place!
My wife and I are near the end of a bedroom/bathroom remodel and have a question about what, if any, trim to use around a new closet. I've attached a photo of the new construction (I hope) so you can see what I'm asking about.
The left wall of the closet meets up next to the doorway into the bedroom. On the right side, at the bottom, you can see where the wall ended prior to the closet being added.
The question I have is, should we trim around the closet to match the existing trim in the room or just put a matching piece to terminate the trim at the bottom right? I saved enough trim from the tear-out to accommodate the window we moved but may not have enough matching trim for the closet.
Is it acceptable to leave this small space (36" inside) without trim or will that look silly when the time comes to sell (years away, not on the radar, but someday).
Thanks for your advice.
Dan
dmhoyt is offline   Reply With Quote
Old 06-11-2012, 09:57 PM   #2
Haverhill Trade 1965
Since you may not be able to match the existing without too much expense you could use two blocks at the bottom, (similar to the existing), case the door with narrower stock, and match the short baseboard piece, (bottom left)
Duckweather is offline   Reply With Quote
Old 06-12-2012, 09:47 AM   #3
I do have a plinth similar to what is at the bottom of the bedroom doorway and my idea was to use that to "finish" the piece coming off the wall to the right of the closet.
My wife thinks this will look "ridiculous" and wants me to trim from the bedroom door, the base of the closet's left wall, miter a piece to complete the corner and then put a plinth at either side of the closet door, as all the other (original) doors in the house have.
That little bit I might have enough baseboard trim for but then she also thinks the closet should be trimmed all the way around and that's where we definitely don't have enough of the original to match.
If enough people with finish carpentry post an answer saying it's "okay" to just end the wall moulding with a plinth and leave the closet as is then the project will be done this weekend. Otherwise who knows.
Thanks again!
Old 06-12-2012, 11:06 AM   #4
It's OK. But...
Depends on what you (really She) wants
mae-ling is offline   Reply With Quote
Old 06-12-2012, 07:18 PM   #5
looking at the plinth and base I think a simple 1x, and a piece of band molding on top would be about as close as you could get. Try BROSCO numbers 8180 or 8469 or panel molding 8161
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 01:14 AM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 03:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 07:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
Musty smell from closet after leak Musty General Discussion 2 09-10-2007 09:36 PM
