Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-12-2011, 09:40 AM   #1
rditz's Avatar
opinion on bookshelf
I wanted to make use of the space underneath a set of stairs. So what I came up with was a combination of closet type storage and a bookcase/shelving beside a desk that will have a computer and be a home-office type of workspace. I cut the corner of the shelving (you can see in the picture) for better access.
http://i243.photobucket.com/albums/f...z/SAM_0208.jpg
the question is regarding the top of the shelving.. I think I should cut it to mimic the shelves below. My wife thinks it should be a squared off top. (keep in mind when looking at the picture that it all still needs to be trimmed out and the gaps/spaces will be hidden).
looking for opinions/thoughts on what I have built so far.
thanks
rod
rditz is offline   Reply With Quote
Old 01-12-2011, 02:05 PM   #2
Squared off would look better to me.
Ron
Old 01-12-2011, 02:13 PM   #3
rditz's Avatar
thanks
Old 01-12-2011, 02:51 PM   #4
Handyman
Yep, squared off would look nicer. Would it be possible to cut out one of the risers to sink the shelf unit into the staircase?
canadaclub is offline   Reply With Quote
Old 01-12-2011, 02:54 PM   #5
rditz's Avatar
thanks... not cutting risers...
Old 01-13-2011, 04:26 PM   #6
Squared for sure
JohnDeereGreen is offline   Reply With Quote
Old 01-14-2011, 02:43 PM   #7
think about edge banding on the plywood cuts to clean up the appearance.
Where is the handrailing on the stairs?
masterofall is offline   Reply With Quote
Old 01-16-2011, 10:06 AM   #8
Are you going to paint or stain?
beerdog is offline   Reply With Quote
Old 01-17-2011, 12:46 PM   #9
rditz's Avatar
beerdog, it will be stained with cherry based to darken it up.. I will be building my own doors for the storage spaces to hide the stuff that goes in there..
masterofall, railing will be later. I have the upstairs to renovate and will be making an iron railing once I have that done up there.
thanks
Old 01-17-2011, 06:51 PM   #10
Stairguy
one more for square
Millertyme is offline   Reply With Quote
Old 01-17-2011, 10:26 PM   #11
if you are staining it i would also make the top panel run the entire lengh, but doors may make that unneeded.
MAke the end sqaure.
Old 01-18-2011, 12:22 PM   #12
rditz's Avatar
I appreciate everyone's opinions on this... but I had a vision and decided to continue down the path I planned...
here it is trimmed out. will be puttying nail holes and staining this weekend...
here it is now...
http://i243.photobucket.com/albums/f...SAM_0213-1.jpg
again, I appreciate the input
rod
Old 01-18-2011, 01:29 PM   #13
A Little Of Everything
Hey that looks nice! Good job!
The only thing that makes me scratch my head wondering is this: Will there by any problem with the unsupported outer-left part of the shelves sagging?
Again though, looks good!
DrHicks is offline   Reply With Quote
Old 01-18-2011, 01:39 PM   #14
rditz's Avatar
DrHicks,
thank you for your comments... I don't think there will be a problem with sagging as the left support is 10" wide. I don't think there will be anything "TOO" heavy on the shelves, but just the same, you never know...
it is all 3/4" plywood and my total span is 38"... it should be ok...
thanks again for your opinion.
rod
Old 01-18-2011, 01:50 PM   #15
Originally Posted by rditz View Post
DrHicks,
rod
Aaahhhh. Gotcha. For some reason it looked bigger than that to me.
I guess if there ever is a problem, you can always add some sort of support.
Even so, nice job!
How to secure a bookshelf without using screws or nails? samdi General Discussion 6 09-14-2010 02:12 PM
J-B Weld to Mount Metal Box HooKooDooKu Electrical 161 02-04-2010 12:12 PM
Hanging a bookshelf on the wall Cobb General Discussion 5 12-10-2008 09:10 AM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 12:14 PM
Looking for a roofer's opinion kwill1229 Roofing 15 08-14-2006 10:19 PM
