-   -   opinion on bookshelf (http://www.diychatroom.com/f14/opinion-bookshelf-92066/)
rditz 01-12-2011 09:40 AM
I wanted to make use of the space underneath a set of stairs. So what I came up with was a combination of closet type storage and a bookcase/shelving beside a desk that will have a computer and be a home-office type of workspace. I cut the corner of the shelving (you can see in the picture) for better access.
http://i243.photobucket.com/albums/f...z/SAM_0208.jpg
the question is regarding the top of the shelving.. I think I should cut it to mimic the shelves below. My wife thinks it should be a squared off top. (keep in mind when looking at the picture that it all still needs to be trimmed out and the gaps/spaces will be hidden).
looking for opinions/thoughts on what I have built so far.
thanks
rod
Ron6519 01-12-2011 02:05 PM
Squared off would look better to me.
Ron
rditz 01-12-2011 02:13 PM
thanks
canadaclub 01-12-2011 02:51 PM
Yep, squared off would look nicer. Would it be possible to cut out one of the risers to sink the shelf unit into the staircase?
rditz 01-12-2011 02:54 PM
thanks... not cutting risers...
JohnDeereGreen 01-13-2011 04:26 PM
Squared for sure
masterofall 01-14-2011 02:43 PM
think about edge banding on the plywood cuts to clean up the appearance.
Where is the handrailing on the stairs?
beerdog 01-16-2011 10:06 AM
Are you going to paint or stain?
rditz 01-17-2011 12:46 PM
beerdog, it will be stained with cherry based to darken it up.. I will be building my own doors for the storage spaces to hide the stuff that goes in there..
masterofall, railing will be later. I have the upstairs to renovate and will be making an iron railing once I have that done up there.
thanks
Millertyme 01-17-2011 06:51 PM
one more for square
beerdog 01-17-2011 10:26 PM
if you are staining it i would also make the top panel run the entire lengh, but doors may make that unneeded.
MAke the end sqaure.
rditz 01-18-2011 12:22 PM
I appreciate everyone's opinions on this... but I had a vision and decided to continue down the path I planned...
here it is trimmed out. will be puttying nail holes and staining this weekend...
here it is now...
http://i243.photobucket.com/albums/f...SAM_0213-1.jpg
again, I appreciate the input
rod
DrHicks 01-18-2011 01:29 PM
Hey that looks nice! Good job!
The only thing that makes me scratch my head wondering is this: Will there by any problem with the unsupported outer-left part of the shelves sagging?
Again though, looks good! :thumbsup:
rditz 01-18-2011 01:39 PM
DrHicks,
thank you for your comments... I don't think there will be a problem with sagging as the left support is 10" wide. I don't think there will be anything "TOO" heavy on the shelves, but just the same, you never know...
it is all 3/4" plywood and my total span is 38"... it should be ok...
thanks again for your opinion.
rod
DrHicks 01-18-2011 01:50 PM
Originally Posted by rditz (Post 573090)
DrHicks,
rod
Aaahhhh. Gotcha. For some reason it looked bigger than that to me.
I guess if there ever is a problem, you can always add some sort of support.
Even so, nice job! :)
