Open Truss ?s - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-09-2006, 10:02 PM   #1
Open Truss ?s
ok heres a few ?s I thought i would ask cause I got no real answers on it from any place i asked about open webbed trusses made of 2*4. 1st ? is what is the max length of the trusses. I figured max span is 30feet with no support. But do they come bigger then 30. Say 60 cause i figure you can put a beam under them in the middle and they should be good to go right?? Or is it the say as putting 2*12 trusses in where they just sit next to each other on the beam
cloudkicker101 is offline   Reply With Quote
Old 04-09-2006, 10:24 PM   #2
renovations
If you go to the truss company they will design trusses for your application. Around here they will do this for free, at least for an estimate. There is no 'maximum span' for a 2x4 bottom chord. Trusses don't work like a beam, where to get twice as far you put a support halfway.
Bonus is offline   Reply With Quote
Old 04-10-2006, 08:40 AM   #3
Contractor
Like Bonus said. Designing trusses is the business of an engineer, not DIY'rs.
Teetorbilt is offline   Reply With Quote
Which way should kitchen cabinets open??? ncoppola09 Carpentry 8 06-30-2007 05:39 PM
? about 70's cape and how to open rooms angelonbreak Remodeling 3 04-25-2007 07:59 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
Stick built to truss conversion mikemc411 Building & Construction 7 09-15-2006 06:06 AM
