Open Stairway To Finished Attic. - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 10:46 AM   #1
Open Stairway to finished attic.
I have a straight set of regular stairs that lead up to our attic bedroom. The stairs come up right in the middle of the room and are open on both sides - no half walls or railings. I am wondering if a low wall on both sides will make the room look too small. Would it be better to go with an open railing? Need some input. Thanks.
rsimons391 is offline   Reply With Quote
Old 02-07-2011, 06:07 PM   #2
Rewards Points: 5,336
Mock up a 36" wall and see what it looks like, then decide.
Ron
Old 02-07-2011, 07:04 PM   #3
Experienced
Jackofall1's Avatar
I would be going for railing to keep the openness of the room, it will look bigger since the stair arrives in the middle of the room
Mark
Old 02-07-2011, 10:18 PM   #4
remodeling pro
I don't mind walls if there is room to do something like bookcases or display cabinets on the sides, but if space only allows standard wall thickness, I prefer to use an open railing. Also depends a lot on the size and height of the space, as the walls will cause a visual block, and may overpower a small space.
troubleseeker is offline   Reply With Quote
Old 02-08-2011, 10:02 PM   #5
Ravenworks's Avatar
Originally Posted by troubleseeker View Post
I don't mind walls if there is room to do something like bookcases or display cabinets on the sides, but if space only allows standard wall thickness.
I just did this with my home,I opted for a 36" wall with bookcases.
Ravenworks is offline   Reply With Quote
Old 02-09-2011, 08:11 AM   #6
DIY staff
Rewards Points: 7,174
In order to save space and give you a nicer look----If you want a book case wall--you won't need any 2x4 framing or drywall---Just the cabinet work---Mike---
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Insulating a full height walk up attic stairway steveel Building & Construction 5 10-05-2010 05:44 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 01:47 PM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 05:27 PM
Best way to open up attic space? bpchevyguy Building & Construction 7 07-03-2008 07:19 AM
