Open Staircase
Originally Posted by wooworkbykirk
remove the ballister, cut the threads flush with the drywall then frame a wall hard to the stairs
Basically that is correct but more than likely the outside stringer is studded up under, so that stringer would need to be moved inside the newly framed wall with a 2X4 spacer nailed flush with the bottom edge of the stringer for sheet rock and a skirt board to slide down between the stringer and the wall, so the stairs would need to be disassembled.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
