Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-08-2010, 08:23 PM   #1
Online source for baseboard molding
I have some baseboard in my house I need to match.
Anyone have an online source I could look at photos and styles to see what I have?
theedudenator is offline   Reply With Quote
Old 03-09-2010, 06:52 AM   #2
Lumberyards and mayne even big box stores have printed molding profiles for stock or standard moldings. If you have something old or special, it will likely have to be custom made.
Old 03-09-2010, 04:08 PM   #3
Drywall contractor
Check with a millworks if there is one near you....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-09-2010, 06:52 PM   #4
I am not sure where you are located but I ended up buying my moulding from a distributor of El & El
http://elandelwoodproducts.com/
Jawbreaker is offline   Reply With Quote
Old 03-10-2010, 10:53 AM   #5
remodeling pro
Check out jbros.com, site for Johnson Brothers. They have a catalogue of profiles you can view on line. Although they list the profiles with numbers with "jb" prefixes, they pretty much are the industry standard "wm" prefix profiles. Wherever you look, you will see profiles listed by a number such as "wm275" . The wm is the industry wide design specs for that profile as set by the Wood Moulding and Millwork Producers Association, so that in theory every manufacturers "wm275" is identical. I say "in theory", because even mouldings from different manufacturing runs of the same supplier will vary slightly, depending on the particular set of knives used for the run.
The big boxes usually have tear off sheets hanging on the moulding isles that you can take, and most lumber yards will have an in house catalogue of the standard wm profiles.
Take note that even if you find the profile at a big box, the thickness of the stock will most likely be thinner than the same profile from a lumber yard or mill supplier.
There are also lots of profiles in older buildings that were manufactured by local or regional millwork producers that had their own "in house" profiles but are no longer in business.
troubleseeker is offline   Reply With Quote
Old 03-10-2010, 11:26 AM   #6
DIYer
jpsmith's Avatar
Here's another.
http://www.senecalumber.com/molding.htm
-Jack
jpsmith is offline   Reply With Quote
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Paint Crown Molding Before or After Installation? gmhut Painting 24 06-03-2009 09:38 PM
wire hanger online source? Clutchcargo Electrical 3 07-10-2008 07:08 AM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
