This door has begun sag under it's own weight (I think). The hinge side of the door has a gap of about 1/4 inch at the top right side. The gap at the bottom right below the lowest hinge is only 1/16th. Thus the top left of the door on the lock side rubs on the frame.
I took the top hinge off and found a spacer behind it. Is this common? Is it a must have?
I took the spacer out and reinstalled the hinge. This has pulled the door to the right enough so that it no longer rubs at the left top (lock side).
I'm not comfortable with this fix and consider it temporary. With that in mind I'd like to know if there is a better way to resolve the problem?
I'm no carpenter, but then you already knew that. :laughing:
Thanks for the information Bob. This morning I took the packing out of the middle hinge. The opens and closes nicely now, but the gap between the the hinge side of slab and jam is still wider than the gap at the bottom.
If I pack the bottom hinge I think the door will rub at the bottom jam on the lock side of the slab. The door currently clears there but only by a about 1/32 inch.
If I cut the top hinge deeper it will make the gap on the lock side at the top wider. It is already 1/8 there. I guess I'll have to leave well enough alone. :huh:
I am not trying to post. I was trying to answer the individual with the sagging Brosco door.
Take 2 precise measurements of the door.
1. top right to bottom left
2 top left to bottom right
If they do not match the door is a parallogram.....not a perfect rectangle and no amount of shimming will help. The door must be removed and clamped to straighten it out. It should be sealed and refinished as well as nailed or dowelled while clamped. The labor and/or inconvenience incurred would probably push the owner to a new door.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
