Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-04-2010, 09:23 AM   #1
Old windows with weights and cords
I have replaced all of the broken weight cords in my windows but have two that wont stay open (up) without using a block of wood to keep the window open. The cords were cut to the same size as the old broken cords. The windows are original to the house from 1906. Help! Thanks.
jhager is offline   Reply With Quote
Old 05-04-2010, 09:27 AM   #2
did they stay up before? may be wrong weights
The older I get the better I was
Old 05-04-2010, 09:41 AM   #3
tpolk, I dont know as the cords were broken when I bought "this old house" however all the weights are the same size (47 windows, 13 room house)
Old 05-04-2010, 10:11 AM   #4
i would look at adding weights, sporting goods stores carry lead weights for surf fishing. you can get them in diff weights
Old 05-04-2010, 10:15 AM   #5
You can find sash weights online or at salvage houses, or do what tpolk mentioned and just add weight to them.
cellophane is offline   Reply With Quote
Old 05-04-2010, 10:20 AM   #6
Xtreme DIY'r
Are all the windows the same, these aren't bigger...or maybe just heavier ?
I kept all my old sash weights, I use them for odds & ends
Old 05-04-2010, 10:35 AM   #7
Scuba_Dave, these particular windows are the same size as the other 6 bedroooms. No difference.
Old 05-04-2010, 07:04 PM   #8
Average Joe/ex-Navy IC3
gregzoll's Avatar
Just buy the retro kits that have springs to replace the old weight & pulley system. Or even better yet, get newer triple pane windows that are energy efficient.
Old 05-05-2010, 01:15 PM   #9
Check the glass in those two windows, they may have been replaced with a thicker heaver glass. If that is the case replace the panes or add weight.
hayewe farm is offline   Reply With Quote
Old 05-05-2010, 07:21 PM   #10
If they are double hung, it is possible that the weights for the lower window are not aligned properly with the weights for the upper window inside the weight box. If your weights are getting hung up, the window will not stay open.
Windows is offline   Reply With Quote
Old 05-05-2010, 09:16 PM   #11
Moderator
Open a lower window of ones that does not stay up. Remove the screw 3-4" up from the sill on the jambs where the window slides. This is the weight access door. Only one screw, centered, holding the door in, the top is kept in place by a bent bracket attached to the door. Change to heavier weight (from a real hardware store) or make sure the window cord is the correct length when open (the weight should not be bottomed out, resting on the sill or framing).
Be safe, Gary
Clothes taking longer to dry?
