Old Style Interior Door Hardware - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 11:33 AM   #1
Old style interior door hardware
I have an interior door that has a 3" x 1 1/2" cut out for the hardware which slips inside it. The hardware with the rose is all in one piece. The old hardware has broken and I need to replace it any ideas on how to find a replacement?
Thanks.
B400 is offline   Reply With Quote
Old 05-19-2011, 12:02 PM   #2
Next Time...New Build
Rewards Points: 150
Check a local re-use store if you have one. If not, check around at older antique (junk) stores in your area. Every one of these in my area has what seems like thousands of doors, often times with the hardware still attached.
RickyBobby is offline   Reply With Quote
Old 05-19-2011, 01:48 PM   #3
Rewards Points: 5,336
Thanks.
It sounds like mortise lock hardware, but the dimensions seem unfamiliar. What does," The hardware with the rose is all in one piece." mean?
What part of the hardware is broken?
Does the latch retract when the knob is turned?
Does the latch stay in the housing?
Can you post a picture?
If you have an old local hardware store still around, they might carry replacements if the hardware was prevalent in the area.
Ron
Old 05-19-2011, 03:31 PM   #4
Too Short? Cut it Again!
I work on antique homes and these people are my go to guys for hardware replacement, restoration and repair. If they do not have what broke, they will find it if you put them on the quest. They will not steal your wallet in the process either.
http://www.albarwilmette.com/index.php
Old 05-19-2011, 06:44 PM   #5
The latch had fallen into a steel door jamb, I managed to retrieve it and fix the problem. Thanks for the replies.
Shed Style or Truss? my5sons Building & Construction 42 08-04-2015 05:33 PM
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 02:36 PM
Weatherking drum style furnace with Honeywell s9201a board bobnorman76 HVAC 24 12-18-2010 11:54 AM
Getting new carpet, questions about pad and style MGB_ Flooring 4 01-27-2010 04:37 PM
Help me decide on cabinet style vetting Remodeling 3 01-06-2009 10:28 PM
