Old House, Old Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-15-2007, 01:18 PM   #1
thorin38
Old house, Old doors
I bought an old house that needs a few minor repairs. The problem I am afraid , is the doors. Most of them are 34" wide and all are 84" tall. The entry door is my main concern. I don't want to widen the rough opening, because, the house has stucco siding. I am open to any ideas.
thorin38 is offline   Reply With Quote
Old 10-15-2007, 01:21 PM   #2
What's the question?
You want to replace the front door? I'm sure you can order a 34x84" entry door in a variety of styles at your lumberyard, or window/door supplier.
NateHanson is offline   Reply With Quote
Old 10-16-2007, 08:56 AM   #3
There are many place that make custom made doors. Here is one that has a lot of options http://www.custommade.com/door-gallery.html
jscholl411 is offline   Reply With Quote
Old 10-16-2007, 08:23 PM   #4
kemerick's Avatar
Rewards Points: 87
If you can find a 34" door without having to custom order it, you can always cut the bottom and/or top down to your requirement.
You can do the same to the sides but that will require mortising them which is pretty easy. Just try it out on some practice wood if you are unsure:
http://www.taunton.com/finehomebuild...ge-chisel.aspx
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-31-2007, 05:59 AM   #5
You know what??? A standard exterior door is 36" I would put a standard door in....only for the simple fact that Fridges, furniture....in the future..go through much easier when you don't have to cut them down..!! Ya Know...
localtradesman is offline   Reply With Quote
Old 11-02-2007, 08:46 AM   #6
kemerick's Avatar
Rewards Points: 87
Good point, sawzalls do not leave a very nice finish...
Old 11-03-2007, 06:33 PM   #7
Send a message via AIM to Marlin
I'd go with a standard size door. You can cut the stucco in a nice line with a wetsaw. Cut the opening about five inches wider then the door on each side to give you room for framing. Once the door is in cover the space with a piece of white pine and paint it. That's what was done at my house and I think it looks better then stucco up to the door. If you want to consider it I'll take a picture for you.
Marlin is offline   Reply With Quote
Old 11-13-2007, 12:09 PM   #8
Rewards Points: 14
Unfortunately, you can not cut an 80" door(standard door sold) to 84" inches. His problem is not making it smaller, it's making it taller.
msajeep is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 05:54 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
