Old Exterior Door Wood Casing - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-31-2008, 01:08 AM   #1
Rewards Points: 81
old exterior door wood casing
Hello. I'm replacing a garage door. the replacement door is about 4 and a half inches deep, 31 and a half inches wide, and 81 and a half inches tall (If I recall correctly). In front of the door i had a wood casing that not only covered the spot where the door jamb and rough framing met but it also stuck about a half inch into the gap between the framing and the stucco. In other words, the casing is L shaped if you view if from the end. Can anyone suggest where I can buy some new similar exterior wood casing? Or is my best bet to buy two pieces of wood, one to give support to the end of the stucco and also be wide enough to be flush with the new door sill, and then a second piece to be flush with the first piece and also protrude out from the outside plane of my stucco? thank you.
joefromcal is offline   Reply With Quote
Old 12-31-2008, 02:04 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i belive your talking about a backband ant it is usually 2 pc you can get that detail with azek trim stock or fabicate your own
Tom Struble is offline   Reply With Quote
Old 12-31-2008, 11:26 PM   #3
Rewards Points: 81
hello strublesiding, thanks for the reply and happy new year.
window casing bluefitness Remodeling 1 12-09-2008 07:34 PM
Old Well Pump- No ground? leafy Electrical 27 09-24-2008 12:16 AM
window casing stool help? Images posted chinese_lover Carpentry 12 07-23-2008 10:04 AM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
Correct way to install aluminum window casing? DavesHammer Remodeling 7 01-16-2008 01:39 PM
