#1 |
old doors new hinges
hello, here's my issue. i am adding some recycled doors to my remodel project. trying to match the existing doors. i am replacing the hinges, but some of the old doors are messed up. i was wondering if i should put the new hinges in the old places or should i router out new mortices? then filling the old mortice with wood putty. the doors are already painted. i heard the mortice is what gives it the strength, not the screws. some of these doors are really messed up. thanks for looking. any suggestions are very well appreiceated.
#2 | |
putty would not be a good choice for filling the old hinge gains. fit a piece of wood in there and sand/paint as required.
I use 7 inches down to the top of the top hinge and 11" up to the bottom of the bottom hinge for 2 hinge doors. 7" down/7"up/centred for 3 hinge doors.
| The Following User Says Thank You to jlhaslip For This Useful Post: | Willie T (03-25-2010) |
#3 |
Mod
If your going to do any filling on the hinge side don't use putty. I always use "Evercoat Formula 27" its a marine grade bondo you mix with a hardener. Tough stuff and you can be sanding on it in about 30 min. Thats assuming the finish is paint.
#4 | |
Old School
old doors new hingesQuote:
One of the best ways you can repair old, reamed-out screw holes is to completely drill the hole (each one) to 1/2", and insert 1/2" oak dowel pieces cut to length and glued in place. Then remount the hinges, screwing the screws into the new oak wood. Drill the holes a couple of inches deep, and pilot drill 1/8", or so, holes for your hinge screws.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 03-25-2010 at 10:42 PM. |
#5 |
Wilie has the right idea it's a lot less work and just as strong. The mortise is there to flush the hinge to the door.
| Tags |
doors, hinges, remodel ![]() |
| Display Modes | |
| Blum hinges from 15 years ago?? | MI-Roger | Carpentry | 14 | 02-23-2010 01:44 PM |
| Cabinet hinges don't fit... arghhhh!!! | pisces7378 | General Discussion | 7 | 12-25-2009 08:47 PM |
| Hidden hinges for 1/2" doors | patcrisp | Carpentry | 3 | 08-29-2009 09:14 PM |
| UGH! A lesson for new Pre-Hung Doors | javan | General Discussion | 6 | 08-08-2008 08:47 PM |
| It's hot outside. Keep the exterior doors and windows closed if running the A/C? | Taylor Crockett | HVAC | 3 | 07-07-2008 06:04 PM |
