Old Bay Window Support - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 07:16 AM   #1
Rewards Points: 1,216
Old bay window support
20 year old Bay Window sagging no cable system for support, two pieces of decorative scroll wood underneath for support (they suck). I was going to dig down below the frost line and install concrete within a sonotube the place a metal jack on it up to the window with a heavy piece of metal shaped like a T from side to side then cover the jack with 5" vinyl to make it look good. Any thoughts or other ideas. Please advise.
COLDIRON is offline   Reply With Quote
Old 11-23-2011, 09:26 AM   #2
Rewards Points: 5,336
Might be hard to jack up an old bay without breaking glass. Depnding on the install, I might just undo the fasteners and then re position the window correctly.
I'd put posts on each side or proper wall brackets to hold it in place.
Ron
B. Franklin 1759
Old 11-26-2011, 06:47 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
is window sagging in front or back? how much is sag? if in back against house? I think I'd try to build a beam, maybe 3 2X8" jack it up, lag bolt 2 of the 3 2X's up tight under window with 1/2 lag bolts into wall studs then cap with third, drill and plug showing 2X and paint to match house. if in front? maybe Jack up 1/4" higher than needed, add 2 decorative scroll under to allow for falling, lag bolt decorative scroll to wall studs, drill and plug to finished look
that's just me, seems simplest?
coupe.
by the way, you related to the drywall company in Avondale PA? I have relatives with that name
coupe is offline   Reply With Quote
Old 11-26-2011, 06:52 PM   #4
Framing Contractor
Rewards Points: 118
If you have enough room underneath, you can probably avoid the footers. Install some wood bracing and then build a box surround that matches the bay profile. The braces can be concealed inside the box, and proper insulation can also be installed.
sixeightten is offline   Reply With Quote
Old 11-26-2011, 06:56 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
For my bay, I first tried the cable system (that sucks too). I ended up having a couple of adjustable brackets made out of iron. It worked perfectly and I could dial in where I wanted the window.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
COLDIRON (11-27-2011)
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 02:42 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
