Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-05-2010, 10:01 AM   #1
OK to use brads making stud wall?
For speed and ease, I'd like to use my Bostitch compressor and brad gun to put together 2x4s in a non-load bearing wall in the cellar. I'm making a workshop and want to put pegboards on the 2x4s to hang my tools.
Is that OK, or must I really use nails?
boru is offline   Reply With Quote
Old 09-05-2010, 10:08 AM   #2
jlhaslip's Avatar
nails. brads aren't long enough or thick enough.
you can use the gun to 'tack' them together, but nails to secure them.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
boru (09-05-2010)
Old 09-05-2010, 01:08 PM   #3
Perhaps you could rent a framing nailer.Your compresser can probably keep up as long as it can deliver enough PSI.
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
boru (09-06-2010)
Old 09-05-2010, 01:21 PM   #4
I know the trend in just about all phases of building is to do it with air tools, but as the other response said - brads are really not sufficient in size or diameter. One other course might be to us 2 1/2 " screws (using your drill/driver - to tack it together, then go with 12 d through sill and top plates for the rest.
I've become quite a proponent of using screws. When you buy quantity you really don't spend alot more and many are coated for exterior use that hold up very well even on beach front homes I've worked on.
If you don't have time to do it right - when will you have time to do it over?
jackofmany is offline   Reply With Quote
The Following User Says Thank You to jackofmany For This Useful Post:
boru (09-06-2010)
Old 09-05-2010, 01:38 PM   #5
uva uvam videndo variafit
WirelessG's Avatar
I agree. Even though it isn't a load bearing wall, it needs to be put together with framing nails. Should someone trip and fall into the wall, the brads will likely pop out.
WirelessG is offline   Reply With Quote
The Following User Says Thank You to WirelessG For This Useful Post:
boru (09-06-2010)
Old 09-05-2010, 02:18 PM   #6
Screws are another great option.The weight of the wall itself never mind a pegboard full of tools would cause brads to fail.Screws would also be cheaper since you probably own a drill or driver already
boru (09-06-2010)
Old 09-15-2010, 08:02 PM   #7
i will tack bits together with 2 1/2 inch brads, just long enough to put a 3 or 4" screw into it.
1910NE is offline   Reply With Quote
Old 09-16-2010, 02:10 AM   #8
liscenced electrician
i use the **** out of my brad nailer to frame, but its only to tack stuff in place. Usually to tack stuff together that im worried i might have to move over an inch, or whatever, after what im building is put together
jimmy21 is offline   Reply With Quote
Old 09-16-2010, 07:46 AM   #9
Moderator
kwikfishron's Avatar
Sounds like a waste of nails to me.
A tape measure and a pencil should help you in not having to move things more than an inch.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 09-16-2010, 12:33 PM   #10
sometimes its not that easy. Only instance i can think of the top of my head was where i was bulding walls, up against the cinderblocks in my basement. The ciderblocks in my basement were very poorly done and they are not flat, straight, plumb, square, etc. So i tacked up a top plate with a brad nailer, where i thought the wall should go, built my wall (using a regular nail gun) and then when it was build i could tap it over to where it looked the best. Then after its in place, nail the top, and drill and anchor the bottom. I guess i could have drew a line on the ground and then ran a plumb bob down the entire length of my basement to make sure it would all work and then keep adjusting it accordingly, but id much rather waste $.25 cents in brad nails to save a half a day in layout
Old 09-17-2010, 12:51 PM   #11
If you're just doing one wall, it should take no time at all to do it the old-fashioned way (framing hammer and 16d nails). And regular construction screws are not code approved for framing.
Tags
brad, stud, wall
range hood through the wall - - -stud in the way pacifier1er Building & Construction 28 08-31-2011 09:53 PM
Removing a stud, not damaging "back" wall JoshuaBaron Building & Construction 13 02-23-2009 10:28 AM
Replacing stud wall behind brick bayoudonnie Building & Construction 1 05-19-2008 10:34 AM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
