Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-22-2012, 07:13 PM   #1
ok how do you do this?
here's a pic of my jig saw so how would I get close enough to cut the back part of this sick hole? What do you guys do in this case?
thanks!
petros151 is offline   Reply With Quote
Old 07-22-2012, 11:01 PM   #2
cut it from the bottom or use roto zip or the scariest thing i have done was use a sawz all
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is online now   Reply With Quote
Old 07-22-2012, 11:23 PM   #3
Keyhole saw?
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
DangerMouse (07-23-2012)
Old 07-22-2012, 11:27 PM   #4
Never had a sink that close.
Sure you are cutting on the sink cut-out line and not the edge of the lip line?
mae-ling is offline   Reply With Quote
Old 07-23-2012, 06:53 AM   #5
Couple tips, you need an all purpose tool to get that close buy@ Harborfrieght, you also need special saw blades to do what your doing the cutting edge reverse so you don't tear the top up or chip.
I had a top like that years ago drove me crazy.
COLDIRON is offline   Reply With Quote
Old 07-23-2012, 08:12 AM   #6
I have the sink template and that's where it puts the back cut out edge. The actual front rim of the sink would be 1 3/4" back from the front of the counterto if I cut it like this.
How far from the front edge is a typical 22" sink set back? If I pull the whole template forward I could get the actual front rim of the sink be 1 1/2" back from the front edge of the countertop. Isn't that too far forward?
Old 07-23-2012, 08:35 AM   #7
Cruising into the sunset
JulieMor's Avatar
I have the same thing. When I made the tight cuts I used a ryoba saw. It makes a clean cut and the width of the blade makes it easy to cut a straight line. The one I have has fine teeth on one side and slightly coarser teeth on the other. It did the job.
JulieMor is offline   Reply With Quote
Old 07-23-2012, 10:56 AM   #8
Retired Cabinetmaker
woody4249's Avatar
Minimum typically on a 25" deep c.top.
At the front the distance is 1 3/4" [1" overhang and 3/4" for the cabinet front facing]
Then you have to consider how to get to the sink clips.
Whats wrong with unscrewing the counter top and moving the c.top forward to cut this?
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 07-23-2012, 11:20 AM   #9
Mike
the countertop is actually not yet attached but you gave me an idea what if I move the c.top fwd and cut the back part from underneath?
i could probably get pretty good access from under the cab...
but if I slide it fwd not sure what that would do since backsplash is
still in the way?
I also think using the robya saw would work fine.
Old 07-23-2012, 11:20 AM   #10
Exclamation
if you have a strong grip, you may use an angle grinder with a thumb switch using a 4" circ. saw blade with a carbide tips. my advise is stop every 12" cut to avoid the blade to heat up due to the RPM of the grinder is too high. But it will do.
markusandrei is offline   Reply With Quote
Old 07-23-2012, 11:32 AM   #11
woody4249's Avatar
still in the way?
Pull the top out and put it on trestles, then cut from bottom side
The Following User Says Thank You to woody4249 For This Useful Post:
petros151 (07-25-2012)
Old 07-23-2012, 11:05 PM   #12
Very Very Dangerous, don't do it
The Following User Says Thank You to mae-ling For This Useful Post:
BigJim (07-25-2012)
Old 07-23-2012, 11:36 PM   #13
use one of these:
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
mae-ling (07-24-2012)
Old 07-25-2012, 04:13 AM   #14
ok I got it done NEVER AGAIN! ow what a pain to have to cut while the countertop is in place. I just did not have the room to easily do the cut off the cabs but if anyone is searching this topic wondering about it dont do it in place do it while the top is off and from underneath.
I DID use the suggestion of sliding the top off a bit and was able to cut the back using a jig saw from underneath and it worked just fine. Thanks for that fine idea.
Old 07-25-2012, 07:59 AM   #15
woody4249's Avatar
You can lead a horse to water but a pencil has to be lead.
Wisdom is the reward for experience
Mike
