Oh, Oh, Sphaghetti O's! - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-14-2014, 07:35 PM   #1
Rewards Points: 89
I would imagine that I would need some sort of adhesive for this. Thoughts?
Fly_on_the_wall is offline   Reply With Quote
Old 01-15-2014, 08:38 AM   #2
joed's Avatar
Rewards Points: 11,614
A coupler of blobs of silicone will glue the back splash back to the wall. Then another bead of clear along the back splash to counter seam.
Old 01-15-2014, 08:57 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Plain ole caulk will work also, if you use caulk to seal the back splash a trick I use is when immediately after applying the caulk while it is still very wet, use a good sharp square edged putty knife and and run along the seam, it will remove all the excess putty and look like it grew there. If you had a putty knife with one edge rounded it will leave a little more caulk but still look good. JMHO
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-15-2014, 06:32 PM   #4
Rewards Points: 89
It worked. Simple. Easy. Thanks everyone.
