-   -   Oh Boy, Stair Help (http://www.diychatroom.com/f14/oh-boy-stair-help-103355/)
Bumthumb 05-02-2011 11:49 AM
Oh Boy, Stair Help
3 Attachment(s)
My good hearted daughter wanted to help fix the stairs in our rental home. She started to take them apart and now I am stuck. How can I get the treads back into the slot of the runner. I do not have access to the back unless I cut a hole in the back of the closet. Any help is greatly appreciated. Prayers will be OK, too.
canadaclub 05-02-2011 12:22 PM
How did she manage to get the treads out of the stringers? You will most likely have to open that closet
Bumthumb 05-02-2011 12:37 PM
Uh, well...,uh...a hammer and a pry bar?:help:
canadaclub 05-02-2011 01:19 PM
AHH! Brute force:wallbash: I love it! You are definitely going to have to open up from behind. You may be able to hammer the stringers back into place but also make a quick inspection to be sure there are no splits in them as a result of the prying. Removing the drywall in the closet is fairly easy..try to take out one big piece with a drywall saw...this will make putting it back easier.
Dave
Bumthumb 05-02-2011 01:49 PM
TANKS Dave, 'preciate it.:thumbsup:
canadaclub 05-02-2011 02:07 PM
Glad to help, but stick around as someone else may very well post another answer.
Dave
sixeightten 05-02-2011 02:12 PM
I think you could add in some nailers from above. I would use screws and glue and pre drill the holes first. I would then cut the stringers long enough to go in each slot 1/2 the depth that they were. A few finish nails above to hold in place.
Keith Mathewson 05-02-2011 08:30 PM
On a housed stair to a basement most likely the wedges were glued to both the tread and skirt. If the glue were doing its job you would almost need a sledge hammer to shift the skirt. Did the stairs seem loose before she worked on them?
Bumthumb 05-03-2011 07:14 AM
Keith,
Yes, that is why she was working on them. Squeeky and a little loose.:whistling2:
Ron6519 05-03-2011 06:04 PM
You'll need to open the entire back of the staircase to fix it correctly. How many of the wedges have fallen to the floor is anybodies guess. You might have a spreading issue with the stringers. You can't usually spread them apart to remove the treads and risers.
Hide the tools from your daughter and give her the landlords phone number.
Ron
canadaclub 05-03-2011 07:11 PM
Ron
Now Ron, think good intentions~:yes:
Keith Mathewson 05-03-2011 07:12 PM
As has been already noted you need to gain access to the underside of the stair. Remove as many wedges as you can, all of them would be preferred. Make new wedges to replace them. You now need to pull the skirt tight to the treads and risers. The skirt should have been shimmed to the studs and nailed off when first installed. Find out if it was, if not you need to do it.
To install the new wedges you may want to know the age of the stair. PVA glues do not bond to themselves on a second glue application. PVA glue came on to the market in the 1950's, prior to that it most likely would have been hide glue. Hide glue will bond to itself and although easy to use you may not be set up to use it. Your best choice may be 2 part epoxy. Coat each surface with epoxy and drive the wedges home. If done correctly will last for many years.
Ron6519 05-03-2011 07:22 PM
Where does that road go paved with these, "good intentions"?
Ron
canadaclub 05-03-2011 08:30 PM
So glad you asked Ron, thanks for playing:laughing:
My daughter used to love helping me with projects. Most times she did pretty good but never had a sense of a true self ability since I was the only one she did work with. Her school reluctantly allowed me to be her employer during an OCAP government program (an introduction to trades for students) and they were surprised when I gave a final mark of 67%
Not because she didn't know the material, but because she did the written test last minute and screwed up.
She earned a scholarship to enroll in a contractors course for women and is mighty fired up now! Sometimes the road to success is paved with just good intent. I know she will be good because her heart is in it
chrisBC 05-03-2011 10:31 PM
edit: yeah after looking that does look like 2x material..closed stairs..
when first looking I thought those "stringers" might be decorative, one piece that fits over the stairs, a buddy of mine did this the other day on a house we were working on, looked very similar.
However obviously when thinking about it if they are now off, it must be a dadoed stringer, as you are asking what to do now and can see it.
Yep, have to get in from behind...Just thinking out loud though-if they are all off currently, you may be able to start at the top or bottom and slide them back in since you have space to access the back. Problem is I'm not sure if you could do this with every one, hard to say without seeing how it's built, just guessing
