Off Topic: Building Cat Scratchers - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-16-2008, 05:39 PM   #1
Rewards Points: 160
Off topic: Building Cat Scratchers
Not sure where to put this post, but I wanted to share with anyone who is interested the cat scratchers I built.
Basic idea is to use Sonotubes for circles and half circles. And get discounted carpet (most places give it for free or $5 - $10.00) end of the roll.
If anyone wants to know more I can post pictures of the simple designs I came up with.
hellothere123 is offline   Reply With Quote
Old 08-16-2008, 07:31 PM   #2
I would like to see the cat scratching post. I volunteer with a cat rescue and we always need them.
darlenep is offline   Reply With Quote
Old 08-17-2008, 05:12 AM   #3
Rewards Points: 160
Here are 2 of the latest ones I've made. Both are made with Sonotube and to attach the sonotube to the base all you have to do is cut a round piece of wood that fits into the bottom of the sonotube. Then staple and glue the round piece to the bottom, then drill from round wood piece into base.
There are TONS of designs on the web, for example this site shows some ideas... http://www.mycatsheaven.com
Just pick a design and its actually less than a half day to build one. I used glue to attach the rug to the sonotube, but after a while realized that to do that it is a lot more work. So what I do is run small boards up the length of the sonotube and then staple through the carpet and sonotube into the wood running up the length to hold it in place.
Let me know if you need any more info.
Off topic: Building Cat Scratchers-p1010001.jpg   Off topic: Building Cat Scratchers-p1010002.jpg
Old 08-17-2008, 10:59 AM   #4
Thank you, those are great.
Old 08-17-2008, 01:23 PM   #5
My cat has one something like that...He still purrrfurs my chair.
Big Bob is offline   Reply With Quote
Old 08-17-2008, 01:30 PM   #6
Rewards Points: 160
The cure for any cat problem.... water in a spray bottle.
Our cats were scratching the couch and making annoying meowing noises and I kept on them every time with the water...they are cured!
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 05:47 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
