Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-16-2011, 11:26 AM   #1
odd size closet openings
i have a closet with the size being 57 x 80 what can i do to put a closet door up? All my closets are that size
packerfanatic 3 is offline   Reply With Quote
Old 01-16-2011, 11:55 AM   #2
Framing Contractor
That's the door rough opening?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-16-2011, 12:42 PM   #3
80" is standard height. The openings were probably made for 5' bipass doors (sliders). They give full access, and are easy to install w/ no modifications.
Dwoodsmith is offline   Reply With Quote
Old 01-16-2011, 12:53 PM   #4
Framing Contractor
80" is standard door height, not rough opening height.
Joe Carola
Old 01-16-2011, 01:08 PM   #5
closet doors slabs aren't quite 80". The whole outfit installs inside and under finished sheetrock. That's what I meant by no modificatoins. Even if 80" is rough framing, it's still tall enough for closet doors. Regular doors should have 82" rough opening. the 80" door slab plus the frame. Closet doors have no frame and are 'retrofit' after sheetrock. They are shortened so there's room for the hanger track at top and carpet at the bottom. All of it fits underneath 80"
Old 01-16-2011, 01:14 PM   #6
Framing Contractor
I'm talking about Prehung doors. We don't know what the OP is talking about yet.
Joe Carola
Old 01-16-2011, 03:07 PM   #7
Bipass doors are not prehung because they aren't hinged. Install, then trim to suit. If the homeowner wanted double swinging doors, the opening IS too small. Both ways. He would need a longer and higher header, and a wider r.o. -82"x62"
Old 01-16-2011, 03:19 PM   #8
Framing Contractor
BipCloset doors have no frame and are 'retrofit' after sheetrock. Bipass doors are not prehung because they aren't hinged. Install, then trim to suit. If the homeowner wanted double swinging doors, the opening IS too small. Both ways. He would need a longer and higher header, and a wider r.o. -82"x62"
That's not true about bipass doors only being hung in sheetrock openings. I've only hung them a few times in sheetrock openings.
I know bipass doors aren't prehung. I've always install jambs first and then the door plus casing. Therefore the RO height has to be bigger than what he has. The width doesn't mater in his case because he can get smaller doors. That's if he's talking about bipass doors, what makes you think he is?
Joe Carola
Old 01-16-2011, 03:48 PM   #9
Tizzer's Avatar
"Bi-Fold" doors here fit in a finished 80 inch opening. Maybe the OP can give a few details about what he wants.
Tizzer is offline   Reply With Quote
Old 01-16-2011, 05:08 PM   #10
bifold doors would work on heighth too. I didn't mention them because they come as 5 footers. Since they don't 'pass' each other in the opening, I'm not sure 57" is wide enough. They might though, it would be worth taking a tape measure to the store to see. As far as 'casing' the opening, if you do it afterwards the casing helps hide the track and the edges of the doors. Plus no remodeling the opening.
Old 01-16-2011, 05:50 PM   #11
Framing Contractor
Is the opening sheetrocked or rough framing? That would clear up all the guessing going on here.
Joe Carola
6 panel bypass closet doors Steve Baumgart Carpentry 5 05-10-2013 09:52 PM
Metal trim around closet openings rovers1973 Drywall & Plaster 8 08-04-2010 11:39 AM
Large metal "tabs" in openings cut in bi-level rim joist... What are they? Insulate? nutlog Building & Construction 9 11-09-2009 04:19 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 07:58 PM
