Odd Shape Door Opening - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 10:36 AM   #1
odd shape door opening
the door opening is not quite a rounded at the top, just at the corners but we would like to have a door installed. so where do I go for something like this, Lowes Home Depot or a custom shop or try to do it ourself?
Sakandpak is offline   Reply With Quote
Old 01-22-2012, 10:38 AM   #2
Military Mom of 4
Snav's Avatar
I say do it yourself - why not? :D
If you buy a solid wood door, however, with a little bit of work and time you can modify it to fit without the cost of paying excessively for a complete custom door.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following 2 Users Say Thank You to Snav For This Useful Post:
mae-ling (01-23-2012), plummen (01-26-2012)
Old 01-22-2012, 10:43 AM   #3
DIY staff
Rewards Points: 7,174
If you can--post a picture--
Do you want a door and frame with a rounded corner?
If not---That opening could be made square again---the rounded corners are,most likely, added to a standard opening as a decorative feature--
Old 01-22-2012, 10:43 AM   #4
Rewards Points: 14,026
Post a picture. Most often it's faster and easer to just remove the whole door frame and all and just install a new prehung door as a unit.
Old 01-22-2012, 12:27 PM   #5
Military Mom of 4
Snav's Avatar
But so boring!
Go for the arched door - it'll be cool, unique and well worth the effort.
Old 01-26-2012, 02:08 PM   #6
No door frame or even doors are perfectly 100% square. You have to create square. You either have to get a pre-hung doors or cut the door to fit the frame. In some cases you may also have to modify the frame slightly with shims and what not.
How To Measure Your Door
http://www.vintagedoors.com/measuredoor.html
jasin is offline   Reply With Quote
Help Reviving Hardwood Floors in Bad Shape Creelove Flooring 6 05-04-2011 01:49 AM
H shape supply trunk Hermand HVAC 3 03-25-2011 10:57 AM
L shape stairs jdel Building & Construction 1 02-15-2009 04:26 PM
Custom Office Desk U Shape Materail? mfleming Carpentry 1 10-21-2008 04:19 PM
T Shape Plug jamiedolan Electrical 4 09-19-2008 07:12 PM
