Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-03-2010, 06:50 PM   #1
oak trim w/ pine door
I have 2 pine doors but would like to use oak for the trim. I am told I can not make them look alike. I am also told that the mixture of woods looks good. Does someone have a picture so I can see for myself?
I will have red oak floors in the mix as well.
aleciadooley is offline   Reply With Quote
Old 04-04-2010, 01:25 AM   #2
If you want to match the doors then use pine trim.
beerdog is offline   Reply With Quote
Old 04-04-2010, 08:00 AM   #3
Pine is fine, oak is fine, pine & oak are fine. Woods get mixed all the time in a variety of applications. If you like it, do it. No they will not match, they are not supposed to.
Old 04-04-2010, 09:09 AM   #4
Moderator
kwikfishron's Avatar
I agree, you might get a peice of oak and pine trim, hold them up there and take a family vote.
kwikfishron is offline   Reply With Quote
Old 04-04-2010, 10:40 AM   #5
match trim/oak color to floor, then fig door color
i like the look of painted jamb and door with stained casing. are baseboard painted?
The older I get the better I was
Old 04-04-2010, 09:32 PM   #6
The two woods have different grain characteristics, so they won't look alike. You can stain them if you want to get them to the same general color. See if you like the results.
Ron
Tags
oak trim w. pine door
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Storm Door Selection/Brand Advice Wanted kc27 General Discussion 3 10-25-2009 09:17 AM
Speed up sanding for window and door trim Karde Carpentry 3 08-23-2009 02:01 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
