Oak Staircase Squeaking So Much - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 09:54 AM   #1
Rewards Points: 35
Oak Staircase Squeaking so much
It started with a small squeak about six months ago on perhaps only one stair riser. Now it's gotten so bad that it's driving me nuts. The house is about 17 years old and under the staircase is another staircase going down to the basement with sheet rock above. Is the only solution to open up the sheet rock on the bottom and try to fix? I don't want to put screws/nails on the top since it's all wood. Thanks Jay.
jay235 is offline   Reply With Quote
Old 07-29-2013, 03:42 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
open up the ceiling below and have someone walk on the stairs so you can what treads are moving which is what causes squeaks.. from there construciton adhesive and glue blocks with screws will fix it up along with shims
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
CENTERLINE MV (07-31-2013)
Old 07-31-2013, 09:09 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
Check the scotia under the nose o the tread sometimes thats what makes the squeak. One brad may do the trick...worth a shot
Millertyme is offline   Reply With Quote
The CELLAR gbwillner Project Showcase 112 02-17-2012 11:00 PM
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 07:16 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 07:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 01:58 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
