Oak Stair Tread And Riser Install Tips - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-04-2012, 12:06 PM   #1
Oak stair tread and riser install tips
I am getting ready to install oak treads and riser on our currently carpeted stairs. Looking for some tips and advice on the installation.
I really can't install over existing treads, as I have been seeing online in the last couple days searching. The steps would have an odd rise on the top and bottom step, ie. 8 1/4" on the bottom step and 6 1/4" on the top.
I believe the only way to do it is to remove the existing treads and risers and install on the new on the stringers themselves. Correct?
Is there any problem doing it this way?
Next question is finishing them, before or after install??
Before would be easier as the kids are in the LL and need to come up stairs for meals and such.
But, if finishing after is better it can be done, just have to go out the LL and come around the house and in through the patio door on the deck.
I already plan to use a good adhesive and 2 1/2" finish nails, installed with a gun.
MTWI is offline   Reply With Quote
Old 05-04-2012, 12:22 PM   #2
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
There are a number of ways to tackle stair / tread replacement. Knowing all the information would be helpful.
Is there access to under the stairs?
Do the stairs run between walls or open one or both sides?
How are the existing stringers to be finished?
Are the treads dado-ed into the stringers?
Can you tackle this project in one go or multiple times?
Is there a banister with spindles attached to the treads?
Woody4249
woody4249 is offline   Reply With Quote
Old 05-04-2012, 01:03 PM   #3
Woody4249
Ok, more info it is.
Stairs are accessible from underneath.
Stairs run between wall, split entry home.
Not sure about that one
Not dado into stringers
It can be done in stages, but both sets of steps need to be accessable to get to the upper level
No spindles on the treads
I'll snap a couple pictures in a bit and post them.
Old 05-04-2012, 05:05 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
if these are stain grade stairs its far easier to put atleast 2 coats of varathane on them before installing. one it makes for less mess afterwords but when it comes time to fill the nail holes the oil from the filler wont bleed into the wood causing a blotchy finish
definitely use constructino adhesive it will give 5 x more holding power than regular wood glue and eliminates squeeks
woodworkbykirk is offline   Reply With Quote
Old 05-04-2012, 05:23 PM   #5
Yes, they are stain grade treads/risers. I will finish them first then, probably a lot easier that way too.
Old 05-04-2012, 05:54 PM   #6
Here are the steps to the LL
And up to the upper level
Old 05-04-2012, 06:46 PM   #7
Looks simple enough. Go for it!
mrgins is offline   Reply With Quote
Stair Tread and Risers tuchodi Flooring 0 08-03-2011 09:38 AM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 09:52 PM
some questions on stair case skirt boarding (how to measure, cut, materials) dwichman Carpentry 2 04-06-2009 06:40 PM
Stair Tread And Riser Installation Speckert General DIY Discussions 3 11-19-2008 03:33 AM
Repairing Broken Stair Tread RonnyK Carpentry 1 05-17-2006 02:37 PM
