Oak Newel Cap Came Off - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 07:42 AM   #1
Oak Newel cap came off
I have a 4" square oak newel at the base of my interior stairwell. Recently the square trim cap came off. It had be glued and stapled with very fine staples at the factory and is composed of a center with laminated edges, solid oak.. I do not want to disturb the finish or corner molding on the underside of the cap or risk misalignment but I want to refasten the cap securely enough that if one of my boys swings around the post in future the cap will not come loose again. Does anyone have as suggested adhesive?or fastening technique. I had thought of drilling with a threaded double ended stud but if I split the cap it will be major work to replace the newel.
The cap is slightly pointed so if I glue it , it will be awkward to clamp as well.
Chemist1961 is offline   Reply With Quote
Old 11-10-2010, 09:34 PM   #2
recently retired
Rewards Points: 280
try using Premium PL Polyurethane.
Keith Mathewson is offline   Reply With Quote
Old 11-11-2010, 01:32 AM   #3
jlhaslip's Avatar
Rewards Points: 980
but be careful, use it sparingly, because it foams up.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 11-11-2010, 08:58 AM   #4
recently retired
Rewards Points: 280
You must be thinking about a different adhesive, PL Premium doesn't foam.
Old 11-11-2010, 09:32 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
PL is construction adhesive
tcleve4911 is offline   Reply With Quote
Old 11-11-2010, 09:39 AM   #6
recently retired
Rewards Points: 280
Thanks, forgot to mention that. It comes in tubes to be used in a caulking gun.
Old 11-11-2010, 08:00 PM   #7
Thanks to all will give it a try
Tags
stair railing / newel
Newel post repair for dummies Zarack Carpentry 17 06-20-2011 05:43 PM
Tighten Loose Nowel Post On Inside Staircase csh49 Carpentry 3 03-12-2010 05:55 PM
Newel Post Installation kcdave Carpentry 3 04-01-2009 07:57 AM
newel fixing to stair landing joanna21 Carpentry 10 02-16-2009 12:23 PM
Newel Post/Balusters question kelrock Carpentry 3 07-02-2008 11:16 AM
