-   -   Oak Newel cap came off (http://www.diychatroom.com/f14/oak-newel-cap-came-off-86330/)
Chemist1961 11-10-2010 06:42 AM
I have a 4" square oak newel at the base of my interior stairwell. Recently the square trim cap came off. It had be glued and stapled with very fine staples at the factory and is composed of a center with laminated edges, solid oak.. I do not want to disturb the finish or corner molding on the underside of the cap or risk misalignment but I want to refasten the cap securely enough that if one of my boys swings around the post in future the cap will not come loose again. Does anyone have as suggested adhesive?or fastening technique. I had thought of drilling with a threaded double ended stud but if I split the cap it will be major work to replace the newel.
The cap is slightly pointed so if I glue it , it will be awkward to clamp as well.
Keith Mathewson 11-10-2010 08:34 PM
try using Premium PL Polyurethane.
jlhaslip 11-11-2010 12:32 AM
but be careful, use it sparingly, because it foams up.
Keith Mathewson 11-11-2010 07:58 AM
You must be thinking about a different adhesive, PL Premium doesn't foam.
tcleve4911 11-11-2010 08:32 AM
PL is construction adhesive
Keith Mathewson 11-11-2010 08:39 AM
Thanks, forgot to mention that. It comes in tubes to be used in a caulking gun.
Chemist1961 11-11-2010 07:00 PM
Thanks to all will give it a try
