Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-21-2009, 05:38 PM   #1
Unhappy
Oak hand rail on existing iron stair railing
I would love to satisfy my wife's wish to enhance our old iron stair railing with an Oak hand rail over the existing iron hand rail held in place with screws up through drilled holes in the iron rail. Is this something that is done? What is involved? My guess is to do it nicely might require channeling out the underside of suitable solid oak hand rail with the channel closely approximating the contour of the iron top's detail which has a typical looking domed center with a couple of rounded little steps on each side. My guess is that such an inlet might be machined into the oak rail underside with something like a special dado set? or multiple passes with various router bits? Obviously by my terminology use and or misuse I am not a wood guy which is why I am here asking after all! Now I can do a fair job with a combo miter saw and I feel I could cut and fit the several pieces of cap required with some amount of confidence. The stairs are in tract home two story, with two flights separated by a double landing which have the first section starting one direction ending on one landing and the second section continuing in the opposite direction off the landing adjacent to the first (which also act as two more stair treads in effect) if any of that makes sense. The stair railings are actually two separate railings as the stair walls negate the need for railing around the inside portions of the landing areas. Bottom line is that it would require 7 individual pieces of "cap" to create an oak handrail. I don't see a way to post a photo or I would. Any ideas? Suggestions? Web sites showing how to? Vendors selling pre-made cap FOR my existing railing??? (that would too much to hope for!) Thanks in advance for any help, so far I can find nothing addressing this need anywhere!
dougworm is offline   Reply With Quote
Old 07-26-2009, 11:01 PM   #2
This seems to me to be an exercise in futility. Handrails are a fairly sofisicated finish carpentry skill set. Piggy backing a wood rail over a metal one is just raising the bar higher.
I don't see a successful end to this endeavor. The metal railing is going to be, what, 1 1/2" wide or more. How wide is this wood railing going to be, to be able to receive this railing into it and still have any meat on the sides?
An alternative, if the baluster tops are round, would be to cut off the metal railing and replacing it with wood. Drill receiving holes for the balusters and epoxy them into the railing.
Is this in your skill set? If not, find another way to keep her happy.
If it is, give it a shot
Ron
Old 07-27-2009, 12:23 AM   #3
I see no benifit to the approach you mention. I am sure it is possible but probably more work. The right way is to remove the iron railing and install the oak hand rail on railing brackets. It is not too difficult depending on your skill set. There are alott of resources on the web about installing handrail and ballustrade. You can also visit most big home centers. They all sell oak handrail parts and have free brochures on the procedure. Or get a book on building stairs or finish carpentry at the library. Either way will give you an idea if it is too much to takle. If it is just a handrail then that is nt too hard, but still not simple. If you need to install ballusters and newells then you are entering a more advanced relm of carpentry. All the cuts MUST be precise so everything fits together nice. Read up on it. MAy also be worth get an estimate from a stair carpenter.
beerdog is offline   Reply With Quote
Old 07-27-2009, 12:53 AM   #4
Building codes guy, Mod
thekctermite's Avatar
Not a strange idea at all...
Several millwork companies in my area manufacture and stock handrail profiles to do exactly what you described. They're simply screwed in place with the screw running up vertically through the iron top cap into the wood.
As previously mentioned, the width of your iron rail's top cap could be a factor. Also, if the top cap isn't reasonably flat and rectangular I'd abort the mission!
Here's an example...
And another...
And another...
Not sure why the top two pics appear to be two pieces. Maybe they are for some reason but that certainly wouldn't be necessary.
If you have access to a router table you could certainly buy the handrail profile of your liking and do as you described with router bits. A stack dado on a table saw would work well, but could be unsafe to mill if the moulding isn't really flat on the bottom and also makes good contact with the fence.
Just be sure that you don't make that handrail too tall by the addition of the cap.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
More On This Topic
Okay so what I am going to be showing you now is how to ride the rail where the lift or takeoff is not directly in front of it, it is more of a hand rail style rail that is meant to represent more sort of the hand rails that go down a stair case. With... Read More »
Grinding a Downhill Rail
Grinding a Downhill Rail by Expert Village
Front side fifty-fifty on a downhill rail. Now that you've learned how to grind a rail consistently, you're ready to bring it to something that goes down and gains speed as you're grinding. What this is going to do is get you ready for some of the street... Read More »
We're going to talk about a more advanced street skating topic which is improving on the ollie, olllieing down the stairs. The key to this trick is having enough speed not too much, not too little when approaching the obstacle. In this case a small 3... Read More »
How to Mime Climbing Stairs
How to Mime Climbing Stairs by Expert Village
Hi! My name is Teri Lynne and I'm here on behalf of Expert Village. In this segment I'm going to show you how to climb a set of stairs, using your mime skills. So this is a side view mime skill. I'm going to start. I'm going to picture I'm going up a... Read More »
Let me show you what you could do with your body, or your legs or your hands after practicing the Iron Bodies. The first thing I'm going to show you to do, breaking the stick with your legs, kicking. Okay. As you could see, my students holding the sticks... Read More »
Replace Wrought Iron interior railing esam75 General Discussion 7 03-20-2009 01:20 AM
Stair spindles-remove wood, add iron Jane Olson Remodeling 3 11-24-2008 02:54 PM
How to best attach heavy iron stair railings to home with vinyl siding Alfredo Building & Construction 1 05-18-2008 08:16 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
