Oak Dust And Polyurethane As A Wood Filler - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 11:07 AM   #1
Oak dust and polyurethane as a wood filler
Anyone have experience with mixing the fine wood dust created by finish sanding oak floors with polyurethane and using the mixture as a filler for floors? If so, advice on mixing ratios, please.
onthebrinck is offline   Reply With Quote
Old 08-11-2011, 11:28 AM   #2
i have heard of mixing the dust and wood glue but not poly.. i would imagine it would be like mixing up hotmud.. start with some dry dust and add poly until its thick enough to trowel around ?
jarheadoo7 is offline   Reply With Quote
Old 08-11-2011, 03:09 PM   #3
Rewards Points: 5,336
How big are the holes?
For small holes, I stain and poly, then fill the holes with the Minwax wax crayons. Wipe off the residue with a damp paint thinner rag. Works very well with finish nail holes.
Ron
B. Franklin 1759
Old 08-11-2011, 05:14 PM   #4
I'd be using this mixture primarily to fill the nail holes created when face nailing the borders and final boards where a mechanical nailer can't reach. I'd also fill minor end gaps and the occasional splintered edge.
I've used Elmer's wood fill in the past and had a tough time matching colors, and I've used Plastic Wood where the color may be closer but the stuff dries out so quickly. I recently tried the Rustoleum trowel-stuff which I very much like for color and workability, but it's a bit to 'liquidy' and required three fills for the nail holes.
Old 08-11-2011, 06:27 PM   #5
I've stated success in filling finish nail holes. You have not stated what size nails you're trying to fill. Face nailing does not tell us what nail size you were using.
This is critical to the advice given.
You have not responded to the solution that has been used in the past.
It would help if you processed the responces and reacted how closely they mimicked your situation.
Ron
B. Franklin 1759
Old 08-12-2011, 01:43 AM   #6
I face nail with 2-1/4" wood screw nails that are countersunk and result in a 3/16" diameter hole about 1/8" to 3/16" deep.
Old 08-12-2011, 06:20 AM   #7
Try the Minwax filler, if you don't like it, go back to the Rustoleum product. You might try building up the product in the hole, proud of the surface, so when it shrinks, it's closer to the floor plane.
Ron
B. Franklin 1759
Old 08-18-2011, 06:43 AM   #8
FWIW: I am using red oak to make new sills for the windows I am replacing in my house. In the shower of the master bath, there are two windows in the corner. I wanted a waterproof filler for the small joint where the two sill pieces join in the corner. I tried mixing fine oak dust with wood glue or polyurethane. Both gave OK results, but I got the best color match using Gorilla epoxy.
David
Jessidog is offline   Reply With Quote
Cement floor dust diyhopeful Flooring 1 09-28-2009 06:10 AM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 08:42 AM
Heavy Dust & Tongue & Groove Ceiling Fix bobricci Flooring 4 11-08-2008 08:47 PM
Between coats of polyurethane on wood floors, how do you get up the dust? proofer Painting 1 04-07-2008 07:27 PM
