-   -   Oak door frames delivered. Wrong size? (http://www.diychatroom.com/f14/oak-door-frames-delivered-wrong-size-182059/)
Mc100 06-18-2013 12:34 PM
Hi all.
We have just ordered 13 new Euro oak rebated frames to replace our existing frames that house 1981 x 838 doors.
After fitting one of the frames I noticed that the carpet room edge strip was about 5mm wider than the door recess. I then tried one of our existing doors in the frame and it fits so snuggly in the frame with no gap whatsoever down the sides.
I rang the joinery company straight away to tell them that they had made the frames incorrectly. The manager told me no, they are correct and the doors need planing. I expressed why should new doors need 4-5 mm planing off them but do not know what is the normal thing that is done here as he told me this is always how frames are made.
Could anybody shed some light for me?
Willie T 06-18-2013 12:55 PM
If you ordered 838mm, you should have received 838mm. He had no way to know what size doors were sitting at your house. And, besides, all your existing doors might not all be the same size.
Mc100 06-18-2013 02:01 PM
Hi Willie.
Thanks for your reply.
Firstly, he came to our house and measured up.
Secondly as it was about 3 months between us placing the order and them actually starting the job I reminded them of the door size we were buying in anticipation they would make the frames to suit and not exactly the same size as the door. I did expect maybe they would make the frame 4mm? oversize
They are brand new doors we are having fitted and presume they will all be 838mm as they are being supplied by a large door manufacturer.
Willie T 06-18-2013 03:01 PM
Oh..... well.... then it does begin to get a bit sticky.
woodworkbykirk 06-18-2013 03:25 PM
if its a larger manufacter i can see a misorder happening. the bigger companies deal in so much volume numbers get lost in the mix.. but trimming them down isnt that big a deal if you have a sharp saw blade and a hand plane nearly to clean up the cut
user1007 06-18-2013 04:29 PM
4-5mm shaved off the edges of a door amounts to a couple passes with a sharp hand or power plane on the hinge and door knob side. It is common to need to shave doors a bit to fit nicely in frames unless everything comes as a pre-hung unit. And, you can remove material but it is difficult to add it!
However, if you are certain they are not the size you ordered and you have more door than that stated you will need to trim then you have an issue. And when you say existing door, is it the same size as the new ones you ordered? Was the hinge still on it?
Duckweather 06-19-2013 09:07 AM
Did the frame maker give you a shop drawing, or order, with the sizes on them, and if yes, do they match the frame? Did you have the new doors available when they measured? I am assuming from your post the frame maker and the door supplier are different companies and you are not using the existing doors, correct.
Mc100 06-19-2013 04:18 PM
Thanks for the replies.
We are also having new doors to go in the new frames. The new doors are exactly the same width as the old ones (836mm).
The doors are coming from a door manufacturer and the frames made at a joiners.
They came to our house to measure up and were given the door width. I thought in giving them the door width they would allow a few mm on top to allow the door to move.
Willie T 06-19-2013 04:32 PM
Well, at least you do have the room now to cut, (or better yet, "plane"), a professional bevel on the lock side. Almost no one does it right these days, and it shows in most door installations.
jagans 06-19-2013 07:37 PM
Amazing how these plots thicken. I would never never never order jambs from one manufacturer, and doors from another, if I understand you correctly
If the doors do not fit after the manufacturers rep did the measuring, they need to make it right.
I also completely agree with the shop drawing issue. You should have gotten shop drawings to sign off on.
You should never have to plane a new door, IMO
