Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-13-2012, 05:46 PM   #1
Unhappy
Oak door
Hello
My son-in-law recently installed my interior oak door and messed up!
He bored the hole for the doorknob and hung it upside down and backwards. This door is for the main floor bathroom and it has a glass inset with the outside of the glass being rippled (which faces the hallway). How can the door be fixed if the doorknob hole is in the wrong place?
Or can it be fixed?
JoJo#7 is offline   Reply With Quote
Old 10-13-2012, 05:50 PM   #2
Oak door
Not likly and not show but post a picture, were not there to see it.
Old 10-13-2012, 09:18 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Oak door
it can be done. it means fixing the hinge gains and getting a stainless steel door plate for the handle to cover the old hole. its common in commercial consruction.. not for the knob to be drilled wrong but the plate
woodworkbykirk is offline   Reply With Quote
Old 10-13-2012, 09:29 PM   #4
Oak door
Not a great look for an inside door.
Old 10-13-2012, 11:10 PM   #5
Oak door
Just drill a bunch of holes in the door and fill them with contrasting walnut plugs.
Yes, I may be a genius.
cleveman is offline   Reply With Quote
Old 10-14-2012, 06:25 PM   #6
funfool's Avatar
Oak door
I have to agree with cleveman here. But a sense of humour is important.
And I have to agree.
Really lets look at your options. You have a door upside down and backwards.
Lets give the kid some credit, only way to do this is by ordering a blank and not a pre-hung door.
In reality, is more skills needed to install a blank, it is possible to make this mistake.
I am sure the son inlaw feels bad about it.
I bet he learn a lesson that he will not repeat, But really, what are your options?
I bet if you order a new blank, tell him to make it right, he will not mess up and make it perfect.
Years ago I made a similar mistake, I always double check now.
But really we all make mistakes, be glad it was on you and not got him fired and affect your daughter and Grand babies.
funfool is online now   Reply With Quote
Old 10-15-2012, 09:10 PM   #7
Wink
Oak door
Yes, the son-in-law feels bad about the mess up, but I still love him nevertheless, and he says it's a lesson learned!
Thanks for all the suggestions ... really do appreciate it!
Old 10-15-2012, 11:00 PM   #8
funfool's Avatar
Oak door
I honestly cant think of a good solution, You know it is upside down, if I were invited into your home and used your bathroom, I would chuckle about it and know it is upside down.
But how many guest in your home are carpenters and would know it was upside down?
Maybe we can declare it a new style and was designed that way?
It does look ok in the photo, nice tight fit and looks clean.
I do not know what effect the rippled glass being on the wrong side will cause, assume is only cosmetic.
If you called me out to look at this and fix it. I would have to suggest a new door.
Once you turn it over and flip it around, put the hardware in correct location which would be on the other side of the door.
Only possible way I can think of saving that door, is to re skin it.
Will be a material made for this at the big box stores or others, will add 1/8" to each side 1/4" total, hinges and or door stops will need to be moved.
Really can be labour intensive to do this, Also will sharpen the son inlaw skills
Again, for me or another carpenter to come out I charge $65 per hour, it would be cheaper to buy a new door.
But if you have the time and skills, could skin it.
The Following User Says Thank You to funfool For This Useful Post:
PaliBob (10-16-2012)
Old 10-16-2012, 04:01 PM   #9
Haverhill Trade 1965
Oak door
[quote=funfool;1031729]I
Try a custom cabinet shop for oak veneer. it is only about 1/16" thick that would only add 1/8" and you might be able to re position the hinges. With caution, contact cement, (the real stuff, lacquer base), would probably be the best adhesive. You roll it, not clamp it, but you can't move it once it makes contact.
Duckweather is offline   Reply With Quote
Old 10-19-2012, 08:33 AM   #10
AHH, SPANS!!!
Oak door
How about a 2 1/2" or 3" round rosette or something like that put over the hole once the door is flipped over. the knob bore hole is 2 1'8" so a 2 1/2" would work. Maybe consider 3 put on that side of the door, one in the (sort of middle ) covering the hole and one at the top and bottom to make it look symmetrical. It is just a way to salvage a nice door and not have to get a new one, doors are not cheap.
BTW, home improvement stores carry some of the little decorative trim pieces. they are in the decorative trim section and the stair parts section
hand drive is offline   Reply With Quote
Old 10-19-2012, 04:20 PM   #11
Oak door
Or you can leave it as-is and call it European-style or something. First one on your block with such a fancy, foo-foo door.
zakany is offline   Reply With Quote
Old 10-20-2012, 10:12 AM   #12
AHH, SPANS!!!
Oak door
left as is the glass is susceptible to breakage do to unaware foot activity(kicking). the glass could be tempered though as it is a full light glass door but doubtful.
Old 10-20-2012, 10:19 AM   #13
Super Moderator
Oak door
That should have come with tempered glass----if bought in the USA or Canada---so I would not be to concerned about breakage---
I would just reverse the glass so the good side faces the right direction and leave it alone---
It will drive you mad---but I bet no living soul will ever notice that the door is upside down---(unless you point it out)
Old 10-20-2012, 11:23 AM   #14
Oak door
Instead of the rosette you could install an 'indicator deadbolt' like so
http://www.qualifiedhardware.com/bra...dbolt-1609.cfm
It may never get used except by guests, but it would be an interesting feature and could make it look like it was done on purpose!
Edit: or you could cover the hole with a rosette and put a keyhole cover in the middle to make it look like a lock without the functionality.
shazapple is offline   Reply With Quote
Old 10-20-2012, 11:46 AM   #15
AHH, SPANS!!!
Oak door
do you know if the indicator deadbolt has a 2 1/8" bore hole, could have 1 5/8" bore hole?
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 10:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
