Originally Posted by jiju1943
You are talking about the angles the cabinets themselves are, we are talking about the angles the crown cuts to, to fit to those angles.
Petros, there are different methods to installing crown and while a 45° can be used at every cut on the cabinets with the 45° center cabinet it is best that you continue the way you are going.
ok thanks- I will keep up with the method I am using and after I'm done I'll research to find out how the 45 thing works. but for now at least the stuff is going up!
I just made a JIG for my little miter saw and I JUST realized that depending on how the jig sets the crown on the bed of the saw it will change the spring angle that the molding need to sit at. So I just got it set right so the molding is sitting at the proper angle on the saw bed. I was holding is there by hand and no wonder I had some gaps!@!@!@!
This is pretty cool, I think I will get this finished by tomorrow. I am going to try coping.
thanks !!!
