Now The Fun Part! Crown Molding On Cabinets Round II - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 05:57 PM   #1
Now the fun part! Crown molding on cabinets round II
Thanks to all here I have gotten good enuf to do do this one run (I posted it again I'm pretty happy with it)
NOW I have the hard part. I've got the 25.5 degree inside angles on the corner cab
I figure for sure cut the center piece of molding and then I am not certain how best to go from there.
I can just take a piece of stock that is longer than let's say the left hand run that goes toward the L outside corner and cut the inside corner onto that piece
then make a cut mark for where the L outside corner needs to be at the end of the run and then do the correct cut for that corner and then I and cut the back piece for the L out side corner and then attach all that and then work on the R side of the run.
I am putting into a notebook all the proper ways to mark and cut each type of corner outside L/R inside L/R and then make sure I do the correct cuts because on the L and R long runs I'll have both an inside and an outside type cut to make and I am sure that can get mixed up if you're not careful.
I may try this tonight if I get a few replies to verify some of this.
THANKS!
Now the fun part! Crown molding on cabinets round II-anglerun112.jpg   Now the fun part! Crown molding on cabinets round II-anglerun111.jpg
petros151 is offline   Reply With Quote
Old 01-17-2012, 07:17 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Cut and install center/angle cabinet, then either left or right, then the other long piece the the two short end pieces.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-17-2012, 07:20 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Whatever works for you.
I always cut the longest pieces first in case you botch it you may still have another long piece to try it again since you didn't cut the little pieces out of your other long piece first.
titanoman is offline   Reply With Quote
Old 01-17-2012, 08:00 PM   #4
Old School
Willie T's Avatar
For the same reason as Titan, I always do all my longer pieces of any trim first.
How is it that you have 25.5 degrees? It should be 22.5.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
mae-ling (01-18-2012)
Old 01-17-2012, 08:43 PM   #5
ok thanks good advice.... TYPO should be 22.5 !
Old 01-18-2012, 06:24 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
The reason I start with my angle piece first is I cut it on a backward angle to lay against the two long cabinets, I then cut the two long pieces on a 22 1/2° then back cope waaaaay back under, not just way back as coping a regular cope but cut waaaay under, the long pieces of crown will lay over the short angle right in place pretty as you please. You won't have to make two 22 1/2° butt cuts to fit with maybe a gap.
Jim
Old 01-18-2012, 07:45 AM   #7
Disabled wood vet
titanoman's Avatar
You can do the same thing (butting one piece into another) doing the long runs first.
(all the cuts are on a 45, not 22-1/2 as you stated).
Old 01-18-2012, 10:22 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
You are right they are on a 45°.(it has been right at 20 years since I last installed like that) But if you do the long piece first you will be able to see the joint easier if you over lap with the short. Also if you are butting the trim instead of coping on those cabinets the cuts will be 22 1/2° at the angle cabinet and 45° at the ends.
Jim
Old 01-18-2012, 01:44 PM   #9
Rewards Points: 2,210
I almost always cope baseboards and crown moulding, but on a cabinet I cut the 45 or 22.5 and butt them. Not sure why just the way I was trained.
mae-ling is offline   Reply With Quote
Old 01-18-2012, 06:47 PM   #10
Disabled wood vet
titanoman's Avatar
That's the only advantage to the short piece going up first is like you said is the higher visibility.
Old 01-18-2012, 08:23 PM   #11
this is tough!
ok here's the latest. I clearly had alot of beginners luck because my first few cuts were nearly perfect. You can see the run I did last night with the inside corners, I did not cope because I had no saw but I bought one although
I am not totally clear yet how to cope saw I"ll try it on this last run
On this cab run (see pic) where there is inside and outside corner that's where my luck ran out. I chopped into about $70 worth of molding and am lucky I have pieces left that I can still use. I put up 3 pieces and then tore it out and I need some help on this one.
Here is what problems I ran into
#1 I was cutting without a jog to hold the molding at spring angle and I now have made a little jig and I assume that will help alot.
#2 I am unclear still exactly how an outside or inside corner measurement is made. For an outside corner I thought you mark the bottom of the molding where the cab ends and then when you turn it
upside down you cut so the saw goes right up to that mark but it is not so easy! sometimes I put the piece up and I'm 1/16" too short or long which causes a gap.
#3 when a piece has an outside AND and inside corner cut I kept getting gaps on the other ends when I cut to make the corners.
(see a pic diagram of the cab run I am on now)
any help really appreciated!!!
Old 01-18-2012, 09:21 PM   #12
Rewards Points: 18
22.5 - yeh, I know, it's half of 45
What am I missing????? I know, a lot!!
But how do u know it's a 45 degree angle, and even if u do, I am missing why/where u are seeing the 22.5 degree.
Can someobody explain or send me a video?
mb88 is offline   Reply With Quote
Old 01-18-2012, 09:28 PM   #13
Disabled wood vet
titanoman's Avatar
It's obvious just by looking at the cabinets what the angles are.
Pretty standard stuff.
Old 01-18-2012, 09:31 PM   #14
Rewards Points: 18
No, it's not to me....and don't want to say it, but a math major here
I see a 90 degree and maybe 45, but 22.5??? dont' see it....maybe I am looking up the wrong avenue.
Old 01-18-2012, 09:36 PM   #15
don;t quote me because I am new BUT if you look at the pic with the cabs already crowned there is a center cab and those angles on the inside corners are 45 so I cut my inside pieces at 22.5 and it fit like a glove. I am not sure why some people said ALL cuts are 45 I do not get that.
If yu look at the NEW set of cabs without crown that I am working on now those are all 90 degree inside and outside corners so each piece I cut at 45
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
What Size Crown Molding? Jim McClain Interior Decorating 1 10-04-2010 07:16 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
crown molding ponch37300 Carpentry 15 06-05-2009 02:35 PM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 01:49 PM
