Notched Joist - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-12-2009, 04:14 PM   #1
Notched joist
Hello,
I'm in the process of remodeling a bathroom. After taking up the subfloor, saw this huge notch in one joist. it's 2x8 and there is about 2 1/2" of wood below the notch. Due to plumbing and HVAC obstructions to the right in the joist cavities, it would be difficult to sister up the joist with any significant lengths of 2x8 or 2x6, plus I'd still need a hole for the 2" drain line that's shown in the picture. I was wondering if a solution could be to sandwich the joist with approx 2" angle iron and through bolt them. I could do this above below the 2" drain pipe using a total of 4 angle pieces w/ bolts. Do you think this would be a suitable fix? If so, how long should the angle be?
Any help would be appreciated.
prghome is offline   Reply With Quote
Old 11-12-2009, 06:21 PM   #2
Registered User
Rewards Points: 526
That is bad. And it's carrying the ceiling with the joist hanger to the left.... With 2- 2x3's (old and new cut joists), I would be worried it couldn't support the toilet. Here are a few ideas: http://www.finehomebuilding.com/PDF/Free/021184090.pdf
http://books.google.com/books?id=1uY...lywood&f=false
http://arch.umd.edu/Tech/Structural_..._Guide_A11.pdf
Be safe, Gary
Old 11-12-2009, 06:24 PM   #3
DIY staff
Rewards Points: 7,174
Nasty place for a notch.
Can you lay your hands on 2 pieces of 1/8 inch or thicker steel--Say ,7" x 30"??
Notch for the pipe--add some 2x to fill the top of the notch and sandwich the bad joist in between the steel? through bolts with washers--Strong--Best you can hope for,I think.--MIKE--
Old 11-12-2009, 07:47 PM   #4
Thanks Gary & Mike.
Like the steel idea which would seem better than the multiple angle iron pieces. Should help in the tight quarters. I'll see what I can find. Any suggestions on bolt pattern/qty?
Old 11-12-2009, 09:36 PM   #5
DIY staff
8 total--4 on each side of the notch.You will have to figure the best pattern-you are on site -boss of the job! Sounds like you've got a solution.
Good luck-Have fun. Post a picture if it turns out nice.----MIKE--
Old 11-13-2009, 12:31 AM   #6
DIY staff
By the way--Steel up to 1/8 inch thick can be sawed with a skill saw using an old fine toothed blade
(all steel, plywood blade is ideal) start slow -sparks will fly--the friction actually melts the steel and gives you a clean cut.
Do this out side-away from flammables. They used to make a smooth blade(no teeth) for cutting steel-- I haven't seen one in many years.--MIKE--
Old 11-13-2009, 05:48 AM   #7
Thanks for all the help. I"ll let you know how I make out.
Pete
Old 11-13-2009, 07:23 AM   #8
A 5" angle grinder works alot better.
bronco2 is offline   Reply With Quote
Old 11-13-2009, 05:55 PM   #9
DIY staff
True about the angle grinder-But most DIY types own a skill saw--not all own an angle grinder.
The method I described really does work well,I have cut a good bit of 1/8 inch stock that way.
I even cut up an old pick-up truck--Frame and all. I'll bet that would have eaten up a lot of grinder blades!!--MIKE--
Old 11-14-2009, 07:05 AM   #10
True.
Old 11-14-2009, 07:17 AM   #11
DIY staff
I really like a cutting torch!!!!
Real mens tools make lot of noise! Flames and explosions.
The local Paramedics actually gave me a new address sign about 10 years ago. I kind of had a bad year!!
As always --work safe--quit when you are tired--(or frustrated)-MIKE--
Old 11-14-2009, 10:13 PM   #12
Registered User
Termite's Avatar
Although the steel idea is valid, it should be noted that only a qualified engineer should be making recommendations for repair (as opposed to replacement) of this notch. Simply bolting steel to it seems logical but may not hold water in the real world, especially when the inspector on your project asks you for the engineering documentation to support the method of repair.
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
i beam in basement, notched joist component Building & Construction 1 03-18-2008 01:47 AM
