No Room For Trim Above Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 09:57 PM   #1
No room for trim above door
Hi,
I was wondering how most of you would tackle this, here's the situation. Door opens into a room right under soffit. R.O. is 6' 8 3/4", gonna have carpet. So I figure it has to hang up 1/2 to 3/4 depending on the carpet. Should I cut the door and jambs down 2 1/2 to make room for trim on top, or leave it as tall as I can and no trim on top? Thanks.
Tom
tomptat is offline   Reply With Quote
Old 12-04-2009, 10:26 PM   #2
Old School
Willie T's Avatar
An uncased door looks awful.
I would make sure everything excess possible is removed from the header.
Then I would make sure the header came down no more than 1-1/2".
That should allow you room to use 2-1/4" casing across the top, with a little adjustment... and a quarter inch reveal when using a normal prehung door.
Then trim (cut) the door bottom as needed.
Willie T
Old 12-04-2009, 10:31 PM   #3
if its a solid door. iwould definetly cut the door, it will mke the wall look taller. imo any way.
roadhouse is offline   Reply With Quote
Old 12-04-2009, 10:31 PM   #4
Where are you located ?
Whats code for your area for min height door ?
If you want to go lower verify w/your building Inspector 1st
Old 12-04-2009, 10:37 PM   #5
codes, itake it somelocations have codes for everything. i could never deal with that.
Old 12-04-2009, 10:42 PM   #6
One of my friends is 6'6", another is 6' 4"
They have codes for a reason
Old 12-04-2009, 10:44 PM   #7
the code around here is duck if the door is to short. lol, all in fun!
Old 12-05-2009, 11:40 PM   #8
PHB Construction LLC
Paulie's Avatar
[quote=roadhouse;361473]the code around here is duck if the door is to short.
Paulie is offline   Reply With Quote
Old 12-06-2009, 03:11 AM   #9
Too Short? Cut it Again!
And as a practical less human factor reason. Try to get furniture of any size through a shortened door! And uncased doors do look awful. Trim the door. Or put down a nice floor and save yourself all the allergens from carpeting?
Old 12-07-2009, 11:15 AM   #10
That sounds very similar to a door we have. We used flat trim on the short side. The top trim is just about 3/4" thick. It doesn't look great, but neither does a squat door, especially if you have another door in the room to compare it to.
In my case, the short side is located so that you're *never* going to be sitting or standing and looking at it, and that migth make a difference.
pyper is offline   Reply With Quote
Old 12-07-2009, 11:37 AM   #11
Old School
Willie T's Avatar
Codes are restrictive enough without us adding to them when there is no such stipulation.
Unless I've missed some recent IRC changes, it's 6'-8" on the dwelling exit door. No such limitation on interior doors.
See "R311.4.2" 2006
Willie T
Rehanging a door: now it won't close ShrimpBurrito Remodeling 19 02-22-2013 11:34 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
