No More Nails? Track Lighting Install - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 12:53 AM   #1
pvg
Question
Hello everyone... looking for some advice here as it hasn't been easy finding information on my situation online...
I'd like to install track lighting in my apartment - the catch being that the ceiling is concrete. Even though I'm the owner, there could be an issue with using concrete screws (tapcon.com) as it could technically be viewed as a modification to the building structure as a whole.
My work around (and let me know if this makes sense) would be to use the "No More Nails Ultra" adhesive (http://www.lepageproducts.com/ProductDetail.aspx?pid=72) to attach the tracks to the ceiling. I've seen solid reviews on the product, and the weight it can handle is far greater than the track/lights combined. I have a popcorn coating on my ceiling (building is a year old so I won't worry about the whole asbestos thing), and am wondering if I should just go for it and stick the track to the ceiling (as-is), or to remove a strip of the popcorn where the track would be prior to fixing to track to the roof?
Let me know what you think... other options are also welcome.
Thank you in advance.
pvg is offline   Reply With Quote
Old 04-03-2011, 01:22 AM   #2
Still Learning
You want the glue to adhere to the concrete, not the popcorn. I would scrape off the popcorn where the lights will be. Also i dont think a few small concrete anchors will cause any problems.
thehvacguy is offline   Reply With Quote
Old 04-03-2011, 03:04 PM   #3
Rewards Points: 5,336
I'd use mechanical fasteners to secure the track to the concrete. Adhesive with an electrical device isn't safe.
Ron
Old 04-03-2011, 07:19 PM   #4
pvg
Originally Posted by Powerup26 View Post
Adhesive wont do anything to electrical. If the lights arent heavy you should be fine. How is the light wired since there is no celing to hide/hold the wires? Need more info before we can proceed
There is an existing light fixture in the ceiling - so the electrical source/wiring isn't really an issue. I'll replace the current fixture with a new primary/canopy piece that provides the electrical feed for the tracks, and the tracks essentially plug-into it. The issue is basically trying to figure out my options for securely fastening the tracks to the ceiling.
Again... many thanks to those that have replied.
Old 04-03-2011, 07:45 PM   #5
pvg
What in trying to get at is how all the exisiting electrical and light is fastened?
Sorry... not familiar with the terminology... pictures speak better than I do:
http://1goodhomeinspection.com/blog/...ure-wiring.jpg
Old 04-03-2011, 08:09 PM   #6
pvg
No I mean how is all it fastened to your celing? I know how lights are hooked up.
The actually metallic/pot-shaped piece to support the fixture? No clue - can't see clearly. I'd assume it would have to be with concrete screws. Which takes me back to the fact that I should be able to use concrete screws to secure the track. I'd like permission from building management before doing so, but then again, I'm sure many others have already drilled into their ceilings at some point.
Old 04-03-2011, 08:11 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
If there's a light there already then any existing fixture should technically be fastened fine the same way. Depending on the type of track light I guess the track portion may require to be fastened more. In that case I think you'd be fine with the adhesive as it's not actually bearing the entire weight of the fixture.
Old 04-03-2011, 09:57 PM   #8
Rewards Points: 29
Tapcons do NOT work well on the vertical in concrete. Because of the variance in aggregate, drilling a perfect tapcon hole in a concrete ceiling is difficult.
Having done this job many times, I suggest you use 3/16" or 1/4" plastic sleeve anchors with 1-1/4" long screws. You should only need to drill into the ceiling 1"+ at the most. This typically will avoid hitting any radiant lines. You can buy a small pack at any big box store. Drill the hole, tap the anchor in, put the track and screw up.
If this is a 4' track that is being centered on the ceiling box and only has 3-4 heads you may be able to get by with gluing the ends.
The track MUST be properly attached to the ceiling box with the correct box/track adapter plate that typically comes with the track.
If this is a longer track, off-center or with more/bigger heads, it is NOT acceptable to glue to ceiling.
Holes can later be easily repaired with caulk or mud and become invisible. Since you have a concrete ceiling, I will assume you are in a Condo/mid-hi-rise building. I suggest you verify if the floor/ceiling contains radiant heat.
Hope that helps.
MarkusAIC is offline   Reply With Quote
Old 04-03-2011, 11:12 PM   #9
Wire Chewer
Rewards Points: 68
I used tapcons in cinder block, maybe it's better in cement, but I found that more then half of them did not actually have a tight stay. So yeah I would not use them vertically.
These would work though:
WAY overkill, but I'm sure they make smaller ones. These apply pressure sideways inside the hole, making them a very strong physical bond.
Old 04-04-2011, 01:23 AM   #10
pvg
Thanks everyone. Definitely have something to work with now...
Install Partition Stud Track over Laminate Floor Andy21 Building & Construction 7 06-24-2011 03:00 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 04:12 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
How to install pendant lighting above an island songbird_63366 Electrical 7 03-11-2009 10:12 PM
Cable track lighting justtired Electrical 10 09-23-2006 01:53 AM
