No Corbels - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 07:59 PM   #1
No corbels
New constructon. 7 foot long, 42" tall kitchen island for bar stool use. 1 foot overhang. The counter top will be granite with thickness yet to be determned. I would like to avoid corbels (knee knockers)
My understanding is that granite should not be overhung by this amount. Any suggestions to support the overhang?
Thanks in advance.
lkg907 is offline   Reply With Quote
Old 02-21-2009, 08:03 PM   #2
the Musigician
DangerMouse's Avatar
make the granite 5 inches thick and no need for support! sorry.... until you know the thickness and weight, there's too many different ways to go. perhaps 3/4 ply under most of it? 1/4" steel plate?
DM
Old 02-23-2009, 12:33 AM   #3
Your granite guy would know best. However if you are the granite guy, of the kitchens I've done in the past with a 1 foot overhang 3/4" ply under 3/4 " granite should be good. Granite running 1 1/14 to 1 1/2 should be ok on its own. In either case I would not bother with the corbels. Anything longer than a foot, I would use them. I've yet to have a call back using this method, however I do tell my customers they are not made to sit on.
Mop in Hand is offline   Reply With Quote
Old 02-23-2009, 09:58 PM   #4
Additional information
The proposed granite is to be 2mm thickness. Thanks
Old 02-24-2009, 10:46 AM   #5
Newbie Bill
Rewards Points: 520
Is this a typo? 2 mm is about 1/10th of an inch.
drtbk4ever is offline   Reply With Quote
Old 02-24-2009, 11:26 AM   #6
the Musigician
darn sure need support under THAT! lol
and corbels sure won't suffice!
DM
Old 02-24-2009, 11:37 AM   #7
I'm guessing it was supposed to be 2cm.
Kiwi. is offline   Reply With Quote
Old 02-24-2009, 12:02 PM   #8
Thank you Kiwi
I apologize to all for not being fluent in metric. 2cm would be correct. But my question still stands.
Old 02-24-2009, 10:20 PM   #9
That's about 3/4". You should be ok with 3/4 plywood under. That's plywood, not mdf.
Old 02-25-2009, 06:27 AM   #10
the Musigician
yup..... i'd route the exposed edge to remove 'sharp' corner and maybe paint it flat black. set it back about 2" should be fine.
DM
wall mount table/countertops? pesphoto Remodeling 11 05-07-2011 07:59 AM
