-   -   No corbels (http://www.diychatroom.com/f14/no-corbels-38866/)
lkg907 02-21-2009 07:59 PM
No corbels
New constructon. 7 foot long, 42" tall kitchen island for bar stool use. 1 foot overhang. The counter top will be granite with thickness yet to be determned. I would like to avoid corbels (knee knockers)
My understanding is that granite should not be overhung by this amount. Any suggestions to support the overhang?
Thanks in advance.
DangerMouse 02-21-2009 08:03 PM
make the granite 5 inches thick and no need for support! sorry.... until you know the thickness and weight, there's too many different ways to go. perhaps 3/4 ply under most of it? 1/4" steel plate?
DM
Mop in Hand 02-23-2009 12:33 AM
Your granite guy would know best. However if you are the granite guy, of the kitchens I've done in the past with a 1 foot overhang 3/4" ply under 3/4 " granite should be good. Granite running 1 1/14 to 1 1/2 should be ok on its own. In either case I would not bother with the corbels. Anything longer than a foot, I would use them. I've yet to have a call back using this method, however I do tell my customers they are not made to sit on.
lkg907 02-23-2009 09:58 PM
Additional information
The proposed granite is to be 2mm thickness. Thanks
drtbk4ever 02-24-2009 10:46 AM
Is this a typo? 2 mm is about 1/10th of an inch.
DangerMouse 02-24-2009 11:26 AM
darn sure need support under THAT! lol
and corbels sure won't suffice!
DM
Kiwi. 02-24-2009 11:37 AM
I'm guessing it was supposed to be 2cm.
lkg907 02-24-2009 12:02 PM
Thank you Kiwi
I apologize to all for not being fluent in metric. 2cm would be correct. But my question still stands.
Mop in Hand 02-24-2009 10:20 PM
That's about 3/4". You should be ok with 3/4 plywood under. That's plywood, not mdf.
DangerMouse 02-25-2009 06:27 AM
yup..... i'd route the exposed edge to remove 'sharp' corner and maybe paint it flat black. set it back about 2" should be fine.
DM
