Newel Post Installation - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 09:35 AM   #1
I'm curious what most use to fasten newel posts. I was looking at using this, http://www.stairservice.com/osc/lj3009-newel-post-anchor3-newels-p-1501.html but it doesn't look like it would hold up real well. I was originally planning to use the LJ toggle bolt, but space is not allowing for it, same with the lag screw fastener they have.
Also, when attaching the handrail I noticed the builders in our area just use finish nails, is this pretty standard or is it better to use the lag fasteners?
kcdave is offline   Reply With Quote
Old 03-31-2009, 07:40 PM   #2
Rewards Points: 5,336
The link you gave is for people who do not want to redo sheetrock or flooring. It's not very solid.
I either open the floor or the ceiling below and drop the newel post into the recess and bolt it to the framing member.
If you have to repaint, you repaint.
Ron
Old 04-01-2009, 06:09 AM   #3
What ron said, if you want it to last.
Old 04-01-2009, 06:57 AM   #4
Rewards Points: 512
Mine is secured to the floor with a metal fastener under the post. It has never been solid, not even when it was installed.
gma2rjc is offline   Reply With Quote
Newel post repair for dummies Zarack Carpentry 17 06-20-2011 04:43 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 09:01 AM
Deck Railing Post installation... davis_mc Building & Construction 14 08-05-2008 03:51 PM
