Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-15-2009, 02:30 AM   #1
newel fixing to stair landing
hi all, i need to fix a newel post to an exsisting landing. the newel finishes short and i want to be able to continue the newel post up to be able to fix handrail and spindles. i know i cant take the exsisting post out , but just need to be able to fix the new one securely. any help on this matter will be appreciated
joanna21 is offline   Reply With Quote
Old 02-15-2009, 06:47 AM   #2
the Musigician
DangerMouse's Avatar
a picture of what you have would help immensely.
DM
RU Crafty? Come join us at www.CraftForum.com !!!
For some Magical Fun, go to:
http://www.youtube.com/user/MickeySoume
Now Featuring: My Canine Assistant Picks the Magic Rising Card!
Old 02-15-2009, 09:15 AM   #3
i have no picture. but there is a false wall there at the moment , that is coming down and being replaced with the newel and handrail and spindles. imagine a landing with nothing there only the floor. i was thinking of housing out the newel post to fit around the floor and then it will sit on the top tread, fixing it to the floor joist. ( im not very good at explaining myself ) sorry that i had no picture
cheers joanna
Old 02-15-2009, 09:34 AM   #4
the Musigician
what is the landing made of? they make all sorts of post mounts that will work for you.
DM
Old 02-15-2009, 01:31 PM   #5
its wooden. its stairs up from a cellar
Old 02-15-2009, 02:30 PM   #6
the Musigician
perhaps a setup like this? it should support 200 lbs lateral load..
this may help too... http://www.thefinishnail.com/newel-p...tion-guide.php
DM
Old 02-15-2009, 03:45 PM   #7
thats an idea , thanks . but maybe to much bespoke joinery for what is priced. thanks again, you have been really helpful
its better if you have a pic. ill get one next time if i need a bit of advice, forward thinking is what i need. where can i buy that ????
cheers joanna
Old 02-15-2009, 03:56 PM   #8
the Musigician
but maybe to much bespoke joinery for what is priced. ? i'm sorry, what do you mean?
DM
Old 02-16-2009, 09:46 AM   #9
Extreme DIY'r Adk's, NY
It's not very clear what you need or want... just google newel fastener. LJ Smith has a pretty good site.
crecore is offline   Reply With Quote
Old 02-16-2009, 12:15 PM   #10
Chicago, IL
Michael Thomas's Avatar
This would be much easier if you took a picture, unloaded to a free hosting site, and posted the link here.
Michael Thomas is offline   Reply With Quote
Old 02-16-2009, 12:23 PM   #11
the Musigician
even easier is hit the 'post reply'/manage attachments/choose/upload/type your response and submit. offsite links don't work sometimes...
=o)
DM
More On This Topic
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
Hi I'm Betty Ingham and I'm speaking on behalf of Expert Village we couldn't replace the white siding because it was just to expensive so we patch it. There's clabber underneath it but it was so rotten that they had already put this siding up years ago... Read More »
And here we are inside the permanent shanty. You can see that it's roughly of an 8 by 6 foot construction. Make out of luan and 2 x 2's cut from 2 x 4's. It has all the amenities of home but in a much, much cruder fashion. Isn't that right great pumpkin... Read More »
How to Repair a Wood Chair
How to Repair a Wood Chair by Expert Village
This is Charles McMahon for Expert Village. We are going to have a look at a project for fixing a broken chair. Now this is a project that you only do if you have some spare time because it would be more cost effective probably just to break the chair up... Read More »
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 10:43 AM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
4'x7' Landing in the middle of stair, glue or floating? liguowei70 Flooring 1 09-06-2007 06:03 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
