Newbie, Is This A Safety Concern? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 12:33 PM   #1
newbie, is this a safety concern?
I had a sump pump installed and a drain system all around the inside of the basement. They cut most of all the wood studs. I will have another contractor fix the drywall and studs and insulation in about 2months. Is it a safety thing not having those studs mounted?
http://imageshack.us/photo/my-images/36/imag0048xm.jpg/
jayk2k3 is offline   Reply With Quote
Old 11-12-2011, 03:06 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
by the looks of things those walls are only perimeter walls for the basement so its not a major saftery concern. however the walls can still go over.. id be withholding pay from the sub contracting and back bill them what cost of fixing the wall. since none of the studs are attached to the sole plate now. the wall is just floating
woodworkbykirk is offline   Reply With Quote
Old 11-12-2011, 04:23 PM   #3
Msradell's Avatar
Rewards Points: 128
Just wondering, what is holding those studs in place? Are they just hanging from the top plate or are they also attached to the concrete wall somehow?
Msradell is offline   Reply With Quote
Old 11-12-2011, 07:28 PM   #4
Rewards Points: 1,574
skyhooks?
bob22 is offline   Reply With Quote
Old 11-12-2011, 10:18 PM   #5
Registered User
Rewards Points: 5,216
Drywall fastened to the studs/top plate and/or the toenails/face nails in the stud/top plate.
Have you found any mold yet? The f.g. is a poor choice against a concrete wall if below grade: http://www.buildingscience.com/docum...lation-systems
Before replacing the bottom plate, add a poly sill sealer under it for a thermal/air/capillary break.
Give the wall a push, if the top doesn't move- it is probably fastened to the joists above, no worries.
Gary
Old 11-13-2011, 01:21 AM   #6
Thadius856's Avatar
Rewards Points: 504
Originally Posted by bob22 View Post
skyhooks?
And toenails.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Hoist safety sumdumguy Safety 2 06-30-2011 09:29 PM
Homeowners And Safety. Roofmaster417 Roofing/Siding 0 05-04-2011 12:41 AM
Safety concern Al wiring? Branden Electrical 8 01-10-2011 05:22 PM
Safety Concern related to bathroom light fixture sooner2k1 Electrical 3 01-10-2008 09:57 PM
Late night safety concern. Please help. sooner2k1 General DIY Discussions 3 01-10-2008 09:28 AM
