Newbie Q?n: Any Rub-on Poly Techniques &/or Tips? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 01:11 PM   #1
Rewards Points: 77
I'm looking to use rub-on poly for my 1st time. What do i need to know? For example:
- direction?
- what about edging?
- biggest or most common mistakes?
- is there a star product that ppl prefer in droves? ... or one to avoid?
I've used brush-on shellac, poly and other varnishes in the past. But never the rub on version, or any other rub-on finish (other than salad bowl varnish). And, my google searches keep pointing me to brush-on finishes (urgh).
Thanks much for your help!
1655graff is offline   Reply With Quote
Old 02-26-2009, 01:22 PM   #2
the Musigician
DangerMouse's Avatar
that's unusual, i google Rub-on Poly and i get this!
http://www.google.com/search?client=...utf-8&oe=utf-8
DM
Old 02-26-2009, 01:43 PM   #3
Remodeling Contractor
Keep a wet over lap. Rub with the grain. Rub the edges last Try to only wipe on with one stroke and rub off to obtain a consistent coat.
Old 02-26-2009, 02:14 PM   #4
Registered User
Termite's Avatar
Use a clean rag folded into a tight wad. Go with the grain, not against it. Remember, this is thinned poly and will penetrate the surface. It does not build like regular poly does.
Don't rub it, just wipe it. One pass to apply, one pass to remove any ponding.
Sand with nothing coarser than 320 between coats. I prefer 400...Lightly!
Old 02-26-2009, 04:38 PM   #5
Rewards Points: 77
Thank you
Thanks Bob & thekctermite!
it sounds like you apply it a lot like what I did for salad bowls.
- I used a cheesecloth back then. I think I'll use that again.
- and 400 & 600 grit... lemme go to that cubby hole and see what I've still got.
BTW, i did read mixed reviews on how well it holds up. have your experiences been good or bad or both?
Old 02-26-2009, 04:42 PM   #6
It is meant to be easy. Not necessarily the best for durability. For that you need a two part poly that adds the hardener at the time of application.
Old 02-26-2009, 04:56 PM   #7
Rewards Points: 77
hm. could you rub-on 2part poly?
Old 02-26-2009, 05:08 PM   #8
no. You use a spray gun. but quality is best you can get.
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 07:29 AM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 11:09 AM
water base poly over oil base poly pappabear Painting 3 08-24-2007 01:53 PM
Poly interior doors gregrice Painting 4 05-15-2006 12:35 PM
