Newbee - I Can't Find T&G Wood Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-05-2008, 10:07 PM   #1
Newbee - I can't find T&G wood siding
I'm trying to restore a 1920's shed that has tongue and groove yellow pine siding that I've researched and found that it's called car siding; pattern 105.
It has a flat face with a 1 1/2" concave top edge along its length. I can't seem to find it anywhere. I can order cedar, but it's cost is startling me. I have Home Depot, Lowes, and 84 Lumber in my area but no one seems to be able to help me. Is anyone out there familiar with this type of siding and can you tell me where I could get it??
Thanks in advance!!!
reba.sue is offline   Reply With Quote
Old 08-05-2008, 11:05 PM   #2
Registered User
Termite's Avatar
You'll have to get car siding at an actual lumber and millwork company. Your average home center won't carry it. Specialty lumberyards normally stock it, or can make it to match your exact profile.
Where are you located?
Old 08-06-2008, 06:32 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
thekctermite is correct i have ordered here on the island from my lumber yard and they had brought it in from there suppliers for me. It came in as common pine. which wasn't bad except for the knots. where as the original had none. thickness was the same. if you go cedar its going to be thinner then the original, so butting to existing be careful. BOB
Old 08-06-2008, 07:09 AM   #4
I'm about 30 miles south of Pittsburgh PA. I can't find or just am not looking in the right direction for a supplier or mill.....
Old 08-06-2008, 07:54 AM   #5
Registered User
Termite's Avatar
I don't know them because I'm in the midwest, but here's what a google search yielded...
Allegheny Millwork & Lumber Co
1001 Muriel Street (10Th Street Bridge)
Pittsburgh, PA 15203
Seaquay Architectural Millwork Corporation
Post Office Box 308
Bridgeport, PA 19405
PRECISION MILLWORK & CABINETRY , INC.
731 E. Bakersville Edie Road
Somerset, PA 15501
......All have websites.
Old 08-08-2008, 01:53 PM   #6
Talking
Thanks so much termite....got the wood at the first mill you listed for me. Mill foreman was really nice to me also. It's great to have cyber-friends!
Old 08-08-2008, 03:31 PM   #7
Registered User
Termite's Avatar
Awesome! Glad to help.
Old 08-08-2008, 08:57 PM   #8
remodeling pro
That is exactly it, called 105 drop siding or car siding. It is readily available, but you will need to go to a "real" lumberyard, not a big box or economy yard like 84 Lumber.
It is available in pine. Be sure to backprime and seal all end cuts with a quality oil primer... the modern pine stuff is going to be a far cry from the quality of the 1920's era material.
troubleseeker is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 10:38 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 07:43 PM
