New Range Hood With Existing Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 10:23 AM   #1
new range hood with existing cabinets
We would like to replace our range hood which currently measures 6'' high (see picture). The range hood we would like to replace it with is 7'' high and I am wondering if it is possible to install it without changing any of the cabinetry. It appears as though there is a 1'' piece (of cabinet/trim) between the current range hood and the upper cabinet. Would it be necessary for me to remove this piece and is it glued on? (I can't see any screw holes from the upper cabinet). Any suggestions/tips would be appreciated. I can provide a better picture this evening if necessary.
Thanks in advance.
cook is offline   Reply With Quote
Old 01-26-2010, 10:32 AM   #2
Rewards Points: 1,016
I don't see a big problem if the new hood has a 1" exposure at the bottom - vs having to do some surgury on the cabinets. Unless there is something objectionable exposed in that 1" of the new hood. And if so, maybe a piece of trim along the exposed sides of the new hood to cover or make it look finished.
Old 01-26-2010, 12:30 PM   #3
Rewards Points: 154
maybe having the new range hood stick our lower by 1" will give it more depth if that makes sense. As long as there is nothing exposed from that 1".
Are you going for stainless steel? What model? Cause I need to replace my range hood as well.
llckll is offline   Reply With Quote
Old 01-26-2010, 12:30 PM   #4
Rewards Points: 154
My guess is you're not going for SS cause your range is currently white along with your dishwasher from what I can see.
Old 01-26-2010, 12:46 PM   #5
going for white - will replace in stainless steel when the appliances go...
Broan (@ lowes) / NuTone (@ home depot) Allure III (http://www.broan.ca/product-detail.asp?ProductID=1121)
thanks for the feedback
Old 01-26-2010, 12:54 PM   #6
jlhaslip's Avatar
Rewards Points: 2,160
That board on the bottom of the cabinet can be removed. It is there for two reasons. 1) spaces the vent from the doors 2) gives a greater thickness for screwing the vent to the box.
Should you remove it, be certain to use shorter screws and ensure the cabinet doors are adjusted to miss the vent.
It would look fine with the board kept in place, IMHO. Of course, you will need a 1/4 " (+/-) spacer at the back to bring it out to the ceramic tile.
*edit*
the board is screwed from the bottom. The screw heads will be visible when you remove the old vent.
An under cabinet valance might be nice there if the vent sticks down too far.
jlhaslip is online now   Reply With Quote
Old 01-26-2010, 01:09 PM   #7
thanks jlhaslip - you've said what I expected (and hoped!). will let you know how it turns out. I'm pretty excited to get started (can you tell I'm new at this?!)
Tags
range hood
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Range Hood install opinion Manshri Appliances 5 01-01-2010 12:04 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
