New Question: Exterior Door Seal Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 06:06 PM   #1
new question: Exterior door seal problem
Hey Bob, another newbie here, and a similar, but not identical situation, so relating to this thread:
I think they are Thermatru; anyway, two prehung inswing insulated exterior doors on a each end of a breezeway, roughed in about 8 yrs ago to open on concrete slab floor in the b-way. We recently added subfloor (DriCore), and removed bottom sweep so as not to interfere with floor (+carpet soon to be installed). Want to convert oak threshold so IT is now the seal, not a sweep on the door bottom. Hard to taper the door bottom because of the vinyl clad door, and existing sill has been all finished in with aluminum clad, etc--a BIG job to replace the entire sill assembly. I was hoping to replace just the wood threshold with a sealing style of the same dimension (width is same as door thickness)--can't find. Alternatively, isn't there some sort of seal that would affix flatly to the threshold, then has a sealing tube attached that the door closes up to, but collapses when you walk on it, or am I dreaming this into existence? What are the options--Thx
tfstix is offline   Reply With Quote
Old 08-11-2010, 08:55 PM   #2
Rewards Points: 5,326
I think Bob is in the john.
Ron
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Door Framing Question biggidybankston Carpentry 4 12-10-2009 01:26 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
