New Patio Step - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 06:31 PM   #1
New patio step
Azek step
Cedar covering wall
Treated wood for base
Local contractor made it in 3 hrs
Old step is the last pic
What do you guys think?
dinosaur1 is offline   Reply With Quote
Old 06-28-2011, 08:32 PM   #2
Rewards Points: 5,336
The old step had more character.
Ron
B. Franklin 1759
Old 06-28-2011, 09:07 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
After thought comments:
A little deeper top tread area would provide a and safer and more comfortable situation.
Is the spry foam foam there to prevent the area under the step from drying out? Water will enter between the treads and from the vinyl channel
Looks like good work that could be done quickly with minimum time and materials.
Dick
concretemasonry is online now   Reply With Quote
Old 06-28-2011, 09:22 PM   #4
Dick
Correct
Overall he did a great job you think?
Old 06-28-2011, 10:01 PM   #5
Originally Posted by dinosaur1 View Post
Correct
No, he did not do a great job. He did the job of an uninformed handyman.
There is no flashing under the door and over the wood. So water will get behind the wood and rot the rim joist and sill plate
He has expanded foam oozing out the side of this step for some reason.
Expanded foam has no business being in an exposed situation. It will deteriorate exposed to the Sun and more water will get behind the step.
Over all, in my opinion, the guy should not be using tools.
He stays in business because he works for people who don't know the difference between a competant and a bad job.
Ron
B. Franklin 1759
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
chrisBC (06-29-2011), kwikfishron (06-29-2011)
Old 06-28-2011, 10:20 PM   #6
Originally Posted by Ron6519
No, he did not do a great job. He did the job of an uniformed handyman.
Actually we have Vulcam sealant all around. The foam is on top of the sealant just as an extra precautionary in that small area. >>>see my water issue thread.
As far as the flashing. Did you look at the old step pic where this OSB (which has Tyvek behind it) was exposed? He placed cedar over that....
Old 06-28-2011, 10:23 PM   #7
Now that I had a chance to read and think, I am glad I said it "LOOKS" like it is good workmanship, but after thinking, the planning and design was more minimal than I quicky thought originally. - The foam did bother me, but that was a good call on the flashing and moisture that has seemed to haunt this home for many reasons.
Dick
Old 06-28-2011, 10:39 PM   #8
Dick
Well....control joints on our poured concrete that drip small amounts of water on the cement floor .....drywall and baseboards which are dry..... has nothing to do with what your mentioning here. That's more of a grading issue or a small crack in the control joint where I might add epoxy injection to fix it.
Old 06-29-2011, 12:06 AM   #9
By the way there is vinyl siding behind the step.
Old 06-29-2011, 06:30 AM   #10
kwikfishron's Avatar
Rewards Points: 436
Thatís not what Iím seeing.
BTW, I could put ďthatĒ step together in about 30 min (or less).
kwikfishron is online now   Reply With Quote
Old 06-29-2011, 07:49 AM   #11
Foam has no use in this allpication. None.
Putting wood under the door without flashing is wrong. I don't care what's in back of it. Tyvek will not keep water away from the sheathing.
You want to push this?
The house is maintenance free. He should have used composite board under the door, not cedar.
He put wood directly on the concrete and then left it exposed to the elements.
He should have applied composite to the bottom to keep the water off the wood.
He should have wrapped the step in composite to make the whole thing maintenance free.
And finally, this is a DIY forum. You've been here awile. This is a simple DIY project.
Why didn't you do it and why are you showing us a picture of a contractors(your term) work?
Posting half assed work by someone else and looking for an "at a boy" is a little pathetic.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
concretemasonry (06-29-2011)
Old 06-29-2011, 07:56 AM   #12
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
ATTA BOY............
How much did that cost?
ATTA BOY..............
Just another example of what kind of thoughtless workmanship is out there....
tcleve4911 is offline   Reply With Quote
Old 06-29-2011, 08:04 AM   #13
Vs badgering people have a little respect man...
Old 06-29-2011, 08:08 AM   #14
Keep water off wood? Lol
Wow I wonder how things like decks and Pergola's survive out there with the same type of treated wood. ....
I'm done here. Thx
Old 06-29-2011, 12:28 PM   #15
Sent you a PM.
Ron
B. Franklin 1759
Constructed maintenance free patio step dinosaur1 Carpentry 11 06-21-2011 05:48 AM
Patio step dinosaur1 Building & Construction 3 05-28-2011 10:14 AM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 11:37 AM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
