New Interior Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 11:57 PM   #1
New interior door
I was lucky when I installed the door to the upstairs in my house. No wires on a non load baring wall. A friend of ours asked if I could do the same for them. I know how to install a door. The question is what if there are wires connecting two outlets where they want the door and how do I tell if its a load baring wall without cutting a bunch of holes to check? any help with this would be greatly appreciated
Rick
rick32 is offline   Reply With Quote
Old 04-14-2012, 12:08 AM   #2
Rewards Points: 12,840
If there's wires your going to have to open up the wall and run a new wire up and over the door and back down to the new outlet.
If it's just a reguler door and not a french door or big opening then it should not matter if it's load bearing or not. It's still going to need a header over the door and cripples over the header that will support the wall.
In that short a space the ceiling not going to move while framing it in.
PaliBob (04-14-2012)
Old 04-14-2012, 09:47 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If you have attic space above or basement/crawl space below. Fish a new wire between the 2 boxes by going up or down.
Coastal South Carolina
Old 04-14-2012, 11:45 AM   #4
Rewards Points: 2,202
There can also be plumbing or HVAC in the walls.
If you can go below and look, see if any wires come up, pipes or other stuff.
If a wire runs from one plug to another you can run it above the door if no header or a small enough header. A double 2x6 easily does most normal situations.
Or go down into a basement or crawl space, or into the attic.
mae-ling is offline   Reply With Quote
Old 04-14-2012, 01:27 PM   #5
Registered User
Rewards Points: 4,914
There is liability involved when doing work for others, especially potential structural work or electrical wiring.
I suggest your friend join our forum for guidance. Or hire a licensed, bonded, and (liability) insured contractor.
Gary
Old 04-14-2012, 01:32 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
you may also need to transfer the load on the header via squash blocks in the floor down to the bearing wall or beam below
woodworkbykirk is online now   Reply With Quote
Old 04-14-2012, 04:21 PM   #7
So much fo cutting a hole and poping it in Thanks for all the input I will know more when I look into it!
Rick
The Following User Says Thank You to rick32 For This Useful Post:
mae-ling (04-14-2012)
